6616 Discussions
The inference engine returns error: clGetPlatformIDs error -1001.
Kevinlin
3 688 Visites
to follow install and problem solved instruction , but still got the error -1001 message.
test environment
  • Ubuntu: 18.04 LTS
  • CPU: i5-1145GRE
  • GPU: Intel® Iris® Xe Graphics
  • Intel OpenVINO toolkit: 2021.2
  • OpenCL runtime library: 20.43.18277
0 Compliments
Kevinlin
3 649 Visites
issue has been solved when Linux kernel version 5.8.0. here is installation information for reference
Version
Ubuntu O/S
20.04 LTS w/ Linux Kernel version 5.8.0
Intel OpenVINO Toolkit
2021.2
OpenCL Driver
manual install 20.43.18277
Voir la solution dans l'envoi d'origine
0 Compliments
5 Réponses
Adli
Modérateur
3 674 Visites
Hi Kevinlin,
Thank you for reaching out to us. If possible, could you share additional information regarding:
  • The command/program that you run when you get the error.
  • Full log error in text/snapshot if available.
Adli
0 Compliments
Kevinlin
3 670 Visites
 to use pedestrian tracker demo in model FP16 :test should loading GPU failed
command line:
person-detection-0101.xml
person-reidentification-0256.xml
error screen shoot
0 Compliments
Adli
Modérateur
3 663 Visites
Hi Kevinlin,
If possible, could you run the 'demo_squeezenet_download_convert_run.bat' infer with GPU? The demo is located in the '<openvino_dir>\deployment_tools\demo' directory. Please share the outcome here.
Adli
0 Compliments
Kevinlin
3 650 Visites
Version
Ubuntu O/S
2021.2
OpenCL Driver
0 Compliments
Adli
Modérateur
3 641 Visites
Hi Kevinlin,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Adli
0 Compliments
Répondre
