Tiny YOLOv3 on NCS2 (FP16) in R5 SDK
nikos1
Valued Contributor I
Anyone managed to get tiny YOLOv3 running on NCS2 in R5?
I am getting
[ ERROR ] [VPU] Internal error: Output in
detector/yolo-v3-tiny/pool2_5/MaxPool has incorrect width dimension.
Expected: 9 or 9 Actual: 10
[ JFTR Non-tiny YOLOv3 now runs fine on NCS2 in the new R5 SDK and same tiny FP16 IR runs fine on GPU  ]
Nikos
Ukhupacha
Hello!
Hyodo, Katsuya wrote:
@Stefano M.
https://github.com/PINTO0309/OpenVINO-YoloV3/blob/master/cpp/README.md
@Peniak, Martin
@Leini, Mikk
@om77
https://github.com/PINTO0309/OpenVINO-YoloV3/issues/7
Thanks for the implementation, I wonder how you came to the conclusion of using mask=3,4,5 because in the original yolo.cfg there are three [yolo] layers. [0,1,2] [3,4,5] and [6,78].
Same thing for yolov3-tiny
Kindly
Ukhupacha
Tsin__Ross
nikos wrote:
Sorry my mistake. Tiny YOLO v3 works fine in R5 SDK on NCS2  with FP16 IR ( size 416x416 ) .
Speed is about 20 fps - impressive!
performance counts:
LeakyReLU_                    OPTIMIZED_OUT  layerType: ReLU               realTime: 0          cpu: 0              execType: ReLU
LeakyReLU_837                 OPTIMIZED_OUT  layerType: ReLU               realTime: 0          cpu: 0              execType: ReLU
LeakyReLU_838                 OPTIMIZED_OUT  layerType: ReLU               realTime: 0          cpu: 0              execType: ReLU
LeakyReLU_838@soc=2/2@accum   EXECUTED       layerType: Convolution        realTime: 277        cpu: 277            execType: Sum
LeakyReLU_839                 OPTIMIZED_OUT  layerType: ReLU               realTime: 0          cpu: 0              execType: ReLU
LeakyReLU_840                 OPTIMIZED_OUT  layerType: ReLU               realTime: 0          cpu: 0              execType: ReLU
LeakyReLU_841                 OPTIMIZED_OUT  layerType: ReLU               realTime: 0          cpu: 0              execType: ReLU
LeakyReLU_842                 OPTIMIZED_OUT  layerType: ReLU               realTime: 0          cpu: 0              execType: ReLU
LeakyReLU_842 -> LeakyReLU... EXECUTED       layerType: Resample           realTime: 217        cpu: 217            execType: Permute
LeakyReLU_843                 OPTIMIZED_OUT  layerType: ReLU               realTime: 0          cpu: 0              execType: ReLU
LeakyReLU_844                 OPTIMIZED_OUT  layerType: ReLU               realTime: 0          cpu: 0              execType: ReLU
LeakyReLU_844@soc=2/2@accum   EXECUTED       layerType: Convolution        realTime: 261        cpu: 261            execType: Sum
LeakyReLU_845                 OPTIMIZED_OUT  layerType: ReLU               realTime: 0          cpu: 0              execType: ReLU
Receive-Tensor                EXECUTED       layerType: Receive-Tensor     realTime: 0          cpu: 0              execType: Receive-Tensor
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 1774       cpu: 1774           execType: MyriadXHwConvolution
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 1766       cpu: 1766           execType: MyriadXHwConvolution + injected[Copy]
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 1770       cpu: 1770           execType: MyriadXHwConvolution + injected[Copy]
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 1769       cpu: 1769           execType: MyriadXHwConvolution + injected[Copy]
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 425        cpu: 425            execType: MyriadXHwConvolution + injected[Copy]
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 22         cpu: 22             execType: Copy
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 1408       cpu: 1408           execType: MyriadXHwConvolution
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 1417       cpu: 1417           execType: MyriadXHwConvolution + injected[Copy]
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 186        cpu: 186            execType: MyriadXHwConvolution + injected[Copy]
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 18         cpu: 18             execType: Copy
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 51         cpu: 51             execType: MyriadXHwConvolution
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 2034       cpu: 2034           execType: MyriadXHwConvolution + injected[Permute]
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 2092       cpu: 2092           execType: MyriadXHwConvolution
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 203        cpu: 203            execType: LeakyRelu
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: RegionYolo         realTime: 13435      cpu: 13435          execType: RegionYolo
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: <Extra>            realTime: 266        cpu: 266            execType: Convert_f16f32
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 325        cpu: 325            execType: MyriadXHwConvolution
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: RegionYolo         realTime: 1278       cpu: 1278           execType: Permute
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 1439       cpu: 1439           execType: MyriadXHwConvolution
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 1290       cpu: 1290           execType: MyriadXHwConvolution
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 1472       cpu: 1472           execType: MyriadXHwConvolution
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 1743       cpu: 1743           execType: MyriadXHwConvolution
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 3417       cpu: 3417           execType: MyriadXHwConvolution
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 3352       cpu: 3352           execType: MyriadXHwConvolution
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 205        cpu: 205            execType: LeakyRelu
detector/yolo-v3-tiny/Conv... EXECUTED       layerType: Convolution        realTime: 336        cpu: 336            execType: MyriadXHwConvolution
detector/yolo-v3-tiny/Resi... EXECUTED       layerType: Resample           realTime: 121        cpu: 121            execType: Resample
detector/yolo-v3-tiny/conc... OPTIMIZED_OUT  layerType: Concat             realTime: 0          cpu: 0              execType: Concat
detector/yolo-v3-tiny/conc... EXECUTED       layerType: Convolution        realTime: 977        cpu: 977            execType: Permute
detector/yolo-v3-tiny/pool... OPTIMIZED_OUT  layerType: Pooling            realTime: 0          cpu: 0              execType: Pooling
detector/yolo-v3-tiny/pool... EXECUTED       layerType: Pooling            realTime: 457        cpu: 457            execType: MyriadXHwPooling + injected[Permute]
detector/yolo-v3-tiny/pool... EXECUTED       layerType: Pooling            realTime: 140        cpu: 140            execType: MyriadXHwPooling
detector/yolo-v3-tiny/pool... EXECUTED       layerType: Pooling            realTime: 1242       cpu: 1242           execType: CopyMakeBorder
inputs@FP16                   EXECUTED       layerType: <Extra>            realTime: 474        cpu: 474            execType: Convert_u8f16
Total time: 47659    microseconds
[ WARN:0] terminating async callback
[ INFO ] Execution successful
How do you do that?
I updated my OpenVINO to the latest version,
when converting .pb model to IR model, I got this,
Model Optimizer version:        1.5.12.49d067a0
[ ERROR ]  List of operations that cannot be converted to IE IR:
[ ERROR ]      LeakyRelu (11)
[ ERROR ]          detector/yolo-v3-tiny/Conv/LeakyRelu
[ ERROR ]          detector/yolo-v3-tiny/Conv_1/LeakyRelu
[ ERROR ]          detector/yolo-v3-tiny/Conv_2/LeakyRelu
[ ERROR ]          detector/yolo-v3-tiny/Conv_3/LeakyRelu
[ ERROR ]          detector/yolo-v3-tiny/Conv_4/LeakyRelu
[ ERROR ]          detector/yolo-v3-tiny/Conv_5/LeakyRelu
[ ERROR ]          detector/yolo-v3-tiny/Conv_6/LeakyRelu
[ ERROR ]          detector/yolo-v3-tiny/Conv_7/LeakyRelu
[ ERROR ]          detector/yolo-v3-tiny/Conv_10/LeakyRelu
[ ERROR ]          detector/yolo-v3-tiny/Conv_11/LeakyRelu
[ ERROR ]          detector/yolo-v3-tiny/Conv_8/LeakyRelu
[ ERROR ]  Part of the nodes was not translated to IE. Stopped.
 For more information please refer to Model Optimizer FAQ (<INSTALL_DIR>/deployment_tools/documentation/docs/MO_FAQ.html), question #24.
Hyodo__Katsuya
Innovator
@Tsin, Ross
Please try below.
sudo -H pip3 install tensorflow==1.12.0 --upgrade
or
sudo -H pip3 install tensorflow-gpu==1.12.0 --upgrade
RTasa
There are a lot or new accelerators out there. The NCS2 is old news in a way with the announcement of Google Coral https://coral.withgoogle.com/ NVIDIA Jetson Nano https://developer.nvidia.com/embedded/buy/jetson-nano-devkit Anyone privy to an insider track on these? Pros cons etc.
