Train on GPU(cuda), use it on NCS
Hello everyone!
I tought i will buy a NCS for my birthday, but i don't know if u will be able to run caffemodels that were made with cuda. My plan is to ise Amazon Web Services instance to train and copy the files to my raspberry. 2nd option would be that i buy a gtx 1050ti and build a real computer to learn deep learning and buy a stick later.
I started to experiment with arch linux because don't like ununtu that much. I used debtap to compile arch package from the deb package for arch arm, but the sdk is a harder job to do. So what do you think?
@addaedans What kind of neural network are you planning to create? The NCS should be able to run inferences on a Caffe network regardless of the training methods used to create it. The NCS SDK is designed to run on an x86 machine with Ubuntu 16.04 so please be aware of that requirement. Good luck on your new project!
