6616 Discussions
Training a network for semantic segmentation
Is the movidius stick suitable to train a semantic segmentation network such unet for example ?
jeanpat
@jeanpat The Movidius NCS meant to do low-power inference at the edge, not training. You can train your networks on your platform of choice and run the model on NCS, just make sure that your CNN is trained using Caffe framework, and it sticks to the layers mentioned in our release notes. Ex. https://ncsforum.movidius.com/discussion/118/movidius-nc-sdk-1-07-07-with-raspberry-pi-support >> NC SDK 1.07.07 Release Notes.
I am trying to use a Caffe trained fully convolution network for "segmentation" and get some errors when use mvNCCompile.pyc. I understand that Movidius is designed only for CNNs, but FCN is more or less the same and all layers the network uses suppose to be supported in the release notes.
After the training (I use digits 5), I downloaded the model, it saves .caffemodel & deploy.prototxt which I used for mvNCCompile.pyc.
The error I get: [Error 17] Toolkit Error: Internal Error: Could not build graph. Missing link: data_preprocessed.
Is there something wrong with my file or am I doing something wrong?
Thank you
The prototxt looks like this:
input: "data"
input_shape {
dim: 1
dim: 3
dim: 281
dim: 500
layer {
type: "Power"
bottom: "data"
top: "data_preprocessed"
power_param {
shift: -116.0
layer {
type: "Convolution"
bottom: "data_preprocessed"
top: "conv1"
convolution_param {
num_output: 96
pad: 100
kernel_size: 11
group: 1
stride: 4
layer {
type: "ReLU"
bottom: "conv1"
top: "conv1"
layer {
type: "Pooling"
bottom: "conv1"
top: "pool1"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "LRN"
bottom: "pool1"
top: "norm1"
lrn_param {
local_size: 5
alpha: 0.0001
beta: 0.75
layer {
type: "Convolution"
bottom: "norm1"
top: "conv2"
convolution_param {
num_output: 256
pad: 2
kernel_size: 5
group: 2
stride: 1
layer {
type: "ReLU"
bottom: "conv2"
top: "conv2"
layer {
type: "Pooling"
bottom: "conv2"
top: "pool2"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "LRN"
bottom: "pool2"
top: "norm2"
lrn_param {
local_size: 5
alpha: 0.0001
beta: 0.75
layer {
type: "Convolution"
bottom: "norm2"
top: "conv3"
convolution_param {
num_output: 384
pad: 1
kernel_size: 3
group: 1
stride: 1
layer {
type: "ReLU"
bottom: "conv3"
top: "conv3"
layer {
type: "Convolution"
bottom: "conv3"
top: "conv4"
convolution_param {
num_output: 384
pad: 1
kernel_size: 3
group: 2
stride: 1
layer {
type: "ReLU"
bottom: "conv4"
top: "conv4"
layer {
type: "Convolution"
bottom: "conv4"
top: "conv5"
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
group: 2
stride: 1
layer {
type: "ReLU"
bottom: "conv5"
top: "conv5"
layer {
type: "Pooling"
bottom: "conv5"
top: "pool5"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "pool5"
top: "fc6"
convolution_param {
num_output: 4096
pad: 0
kernel_size: 6
group: 1
stride: 1
layer {
type: "ReLU"
bottom: "fc6"
top: "fc6"
layer {
type: "Dropout"
bottom: "fc6"
top: "fc6"
dropout_param {
dropout_ratio: 0.5
layer {
type: "Convolution"
bottom: "fc6"
top: "fc7"
convolution_param {
num_output: 4096
pad: 0
kernel_size: 1
group: 1
stride: 1
layer {
type: "ReLU"
bottom: "fc7"
top: "fc7"
layer {
type: "Dropout"
bottom: "fc7"
top: "fc7"
dropout_param {
dropout_ratio: 0.5
layer {
type: "Convolution"
bottom: "fc7"
top: "score_fr"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 21
pad: 0
kernel_size: 1
layer {
type: "Deconvolution"
bottom: "score_fr"
top: "upscore"
param {
lr_mult: 0.0
convolution_param {
num_output: 21
bias_term: false
kernel_size: 63
group: 21
stride: 32
weight_filler {
type: "bilinear"
layer {
type: "Crop"
bottom: "upscore"
bottom: "data"
top: "score"
crop_param {
axis: 2
offset: 18
@klm try to use this prototxt:
name: "TEST" input: "data" input_shape { dim: 1 dim: 3 dim: 281 dim: 500 } layer { name: "shift" type: "Power" bottom: "data" top: "shift" power_param { shift: -116.0 } } layer { name: "conv1" type: "Convolution" bottom: "shift" top: "conv1" convolution_param { num_output: 96 pad: 100 kernel_size: 11 group: 1 stride: 4 } } layer { name: "relu1" type: "ReLU" bottom: "conv1" top: "conv1" } layer { name: "pool1" type: "Pooling" bottom: "conv1" top: "pool1" pooling_param { pool: MAX kernel_size: 3 stride: 2 } } layer { name: "norm1" type: "LRN" bottom: "pool1" top: "norm1" lrn_param { local_size: 5 alpha: 0.0001 beta: 0.75 } } layer { name: "conv2" type: "Convolution" bottom: "norm1" top: "conv2" convolution_param { num_output: 256 pad: 2 kernel_size: 5 group: 2 stride: 1 } } layer { name: "relu2" type: "ReLU" bottom: "conv2" top: "conv2" } layer { name: "pool2" type: "Pooling" bottom: "conv2" top: "pool2" pooling_param { pool: MAX kernel_size: 3 stride: 2 } } layer { name: "norm2" type: "LRN" bottom: "pool2" top: "norm2" lrn_param { local_size: 5 alpha: 0.0001 beta: 0.75 } } layer { name: "conv3" type: "Convolution" bottom: "norm2" top: "conv3" convolution_param { num_output: 384 pad: 1 kernel_size: 3 group: 1 stride: 1 } } layer { name: "relu3" type: "ReLU" bottom: "conv3" top: "conv3" } layer { name: "conv4" type: "Convolution" bottom: "conv3" top: "conv4" convolution_param { num_output: 384 pad: 1 kernel_size: 3 group: 2 stride: 1 } } layer { name: "relu4" type: "ReLU" bottom: "conv4" top: "conv4" } layer { name: "conv5" type: "Convolution" bottom: "conv4" top: "conv5" convolution_param { num_output: 256 pad: 1 kernel_size: 3 group: 2 stride: 1 } } layer { name: "relu5" type: "ReLU" bottom: "conv5" top: "conv5" } layer { name: "pool5" type: "Pooling" bottom: "conv5" top: "pool5" pooling_param { pool: MAX kernel_size: 3 stride: 2 } } layer { name: "fc6" type: "Convolution" bottom: "pool5" top: "fc6" convolution_param { num_output: 4096 pad: 0 kernel_size: 6 group: 1 stride: 1 } } layer { name: "relu6" type: "ReLU" bottom: "fc6" top: "fc6" } layer { name: "drop6" type: "Dropout" bottom: "fc6" top: "fc6" dropout_param { dropout_ratio: 0.5 } } layer { name: "fc7" type: "Convolution" bottom: "fc6" top: "fc7" convolution_param { num_output: 4096 pad: 0 kernel_size: 1 group: 1 stride: 1 } } layer { name: "relu7" type: "ReLU" bottom: "fc7" top: "fc7" } layer { name: "drop7" type: "Dropout" bottom: "fc7" top: "fc7" dropout_param { dropout_ratio: 0.5 } } layer { name: "score_fr" type: "Convolution" bottom: "fc7" top: "score_fr" param { lr_mult: 1.0 decay_mult: 1.0 } param { lr_mult: 2.0 decay_mult: 0.0 } convolution_param { num_output: 21 pad: 0 kernel_size: 1 } } layer { name: "upscore" type: "Deconvolution" bottom: "score_fr" top: "upscore" param { lr_mult: 0.0 } convolution_param { num_output: 21 bias_term: false kernel_size: 63 group: 21 stride: 32 weight_filler { type: "bilinear" } } } layer { name: "score" type: "Crop" bottom: "upscore" bottom: "data" top: "score" crop_param { axis: 2 offset: 18 }
