This would seem to be a big help when maintaining multiple systems, especially the split for development and runtime installs.
I used these instructions:
https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_apt.html
It installed and appears to work when I ignored the "is not signed error" but this is not a viable way to do things.
sudo apt update gives the following error:
W: GPG error: https://apt.repos.intel.com/openvino/2019 all InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY ACFA9FC57E6C5DBE E: The repository 'https://apt.repos.intel.com/openvino/2019 all InRelease' is not signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details.
This is the GPG pub key that downloaded, sudo apt-key add responded with "OK":
-----BEGIN PGP PUBLIC KEY BLOCK----- mQENBFfriU0BCADD98BaTc+sNO2nk7UwfhNIwiyN+8PtoozyIQtITGViuLGTC2f7kcA08blM+pkz qGc9+uYosY5zW++HPowg+b1IEvPAGv1/WzDgCcm8vMbvmgs9GQL64X81mkXglGO1xI7VFQ5KxvQY oaOA4NFSw0L3RTYyGl2AAGRbkEmdUg+6DCUZ5aNp+ZUhH5sV3rpUwWj8aJw/1SUm8KmA6GTb8a+s hQhygablAVyxY29/F4reIYD3TJsnKl9xcoc+NMaT76rOaL9TU71dhn9DRl6I2S63r4QmZXIgcikt vzbWwny8IBPFrh/5HaVh+eGIVg7aC/6ZPvwLzVTiKtywP3JP9OXzABEBAAG1AEIiQ04gPSBJbnRl bChSKSBTb2Z0d2FyZSBEZXZlbG9wbWVudCBQcm9kdWN0cyIsIE89SW50ZWwgQ29ycG9yYXRpb26J AT4EEwEIACgFAlfriU0CGwMFCQWiSQAGCwkIBwMCBhUIAgkKCwQWAgMBAh4BAheAAAoJEBqEl7EZ EeCX1+gH/1ChlnCBN9SqB1xKW6gPPX+9UcqTD+kr1HPve64S0eSoV86U5iKNPVdJ3GcRrEd/hNuh eiazQaxLjHBIkHMbur1x3/91uYFdVOndwKJwIRKZmP2vCjucNb8FO3I4lINevVn7IHTf4hMMyFEd 0ZLBvlmxXqOlV2Tb4ACGFPhLLhKNvkf6TFCCc0VoYmcyNecWEoh2ZZ9w/+uuY2pKkNulrjPFWjKA G1TEIim+KkpzoBjBWAlb+Rf0OkahAWjc0LCbiA22oIdJxwsWYGqlJMSXCB5Q+Vk8duHRIm6tf5L3 7ymDS8lnPgq3871dhD+i5K6LTXdlY9Yk2Nv2BbDLSm42l+A= =r6NW -----END PGP PUBLIC KEY BLOCK-----
Please use another key: https://apt.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS-2019.PUB
Documentation will be updated with the next release.
I have the same issue on Ubuntu 18.04.
Dear Walter and Vadim, thanks for the insight. I have filed a bug on both your behalf.
Shubha
Adding the new key fixed it.
Hopefully the next release will upgrade "automatically after it hits the repos.. IMHO this will be a big win for users.
The current contents of that file are two keys. `apt-key` does not understand it and adds only the first one, thus my problem persists.
-----BEGIN PGP PUBLIC KEY BLOCK----- mQENBFfriU0BCADD98BaTc+sNO2nk7UwfhNIwiyN+8PtoozyIQtITGViuLGTC2f7kcA08blM+pkz qGc9+uYosY5zW++HPowg+b1IEvPAGv1/WzDgCcm8vMbvmgs9GQL64X81mkXglGO1xI7VFQ5KxvQY oaOA4NFSw0L3RTYyGl2AAGRbkEmdUg+6DCUZ5aNp+ZUhH5sV3rpUwWj8aJw/1SUm8KmA6GTb8a+s hQhygablAVyxY29/F4reIYD3TJsnKl9xcoc+NMaT76rOaL9TU71dhn9DRl6I2S63r4QmZXIgcikt vzbWwny8IBPFrh/5HaVh+eGIVg7aC/6ZPvwLzVTiKtywP3JP9OXzABEBAAG1AEIiQ04gPSBJbnRl bChSKSBTb2Z0d2FyZSBEZXZlbG9wbWVudCBQcm9kdWN0cyIsIE89SW50ZWwgQ29ycG9yYXRpb26J AT4EEwEIACgFAlfriU0CGwMFCQWiSQAGCwkIBwMCBhUIAgkKCwQWAgMBAh4BAheAAAoJEBqEl7EZ EeCX1+gH/1ChlnCBN9SqB1xKW6gPPX+9UcqTD+kr1HPve64S0eSoV86U5iKNPVdJ3GcRrEd/hNuh eiazQaxLjHBIkHMbur1x3/91uYFdVOndwKJwIRKZmP2vCjucNb8FO3I4lINevVn7IHTf4hMMyFEd 0ZLBvlmxXqOlV2Tb4ACGFPhLLhKNvkf6TFCCc0VoYmcyNecWEoh2ZZ9w/+uuY2pKkNulrjPFWjKA G1TEIim+KkpzoBjBWAlb+Rf0OkahAWjc0LCbiA22oIdJxwsWYGqlJMSXCB5Q+Vk8duHRIm6tf5L3 7ymDS8lnPgq3871dhD+i5K6LTXdlY9Yk2Nv2BbDLSm42l+A= =r6NW -----END PGP PUBLIC KEY BLOCK----- -----BEGIN PGP PUBLIC KEY BLOCK----- mQENBF2Ru1cBCADET6CERkWEDRAF6GIEceiajgMFT6BepRjF26rtnyEXdAXT4vU+wLqg0DE5Va1t 4ZAXcIHJ3g1OuGw7Vst2b7WySJl1cFvRSOxZg7Em0QUd51c7n0IYX6FL55Ern2pU3sL2NfJnyrKi HBSTBGqMFELF5cTaY4E1GQyIUj0BrwUXMpLuxxL0ISyz2CNFnJuENbunbax0L5LrHLFwcsTEvT9q ZVcP5G+xZBmhPOJ3bR3LHZN/9tj1E6IEzFOY/S/jfqXKmwbR4EzZ7pTtBqNzDm6bviWwQHyh6euw eoDhTa6TAUUsP5vIL+7iWDQd9X10XyByWEsLaQbWNBCPxAwRTAgnABEBAAG1ACZJbnRlbChSKSBT b2Z0d2FyZSBEZXZlbG9wbWVudCBQcm9kdWN0c4kBPgQTAQgAKAUCXZG7VwIbAwUJB4YfgAYLCQgH AwIGFQgCCQoLBBYCAwECHgECF4AACgkQrPqfxX5sXb7L5Qf/cxJs9tDCea0ZWqeSX1lAjuff2Bku H/yXwvu625DcAneUemho6NDck2LJKhpUM/9teyQWGTIIuz8IlIr3zYeK8VmVitm6cgjD07TYeh5j 71eAd7R1o49IUhIx/cXcuBcYHOw9kWCpl05D85xByZxkF7tlShLwVveyNGeVzU8aBJPhqoPGzIP0 /CJ3c2Qe09UMmqyhUw5ETMqBxR1E+vFCqAHfa3VdtOc8gIfmMK50t/wjE33RdnMI0cHoqmRLFj6C ppBjBabIY+ro1focySyJ8cLkVEsk0T6u0s2B8nj+ctjasYAeZCmk6shNh9Y06zHkRcBS/cy2bHeB 4nKs3YBvpA== =aXpT -----END PGP PUBLIC KEY BLOCK-----
Dear Markovtsev, Vadim,
Please download OpenVino 2019R3 (just released today). It should be fixed. apt-get OpenVino Install document was also updated.
New GPG Keys here:
Thanks for your patience !
Shubha
The package name contains version, it means the new package will be installed apart: "/opt/intel/openvino-2019.3.xxx". Thus installation will not be performed automatically by "apt upgrade".
AFAIK, this scheme is used by other Intel libraries distributed via APT/YUM and is partially related to the fact that OpenVINO does not guarantee binary compatibility between releases and requires recompilation of user's applications with each new version. For convenience, symlink "/opt/intel/openvino" will point to the latest release after installation.
Thanks for the clarification, So basically an upgrade is a parallel install of the new version.
so I'd upgrade to R3 with:
sudo apt install openvino-dev-ubuntu16-2019.3.334
to get the most recent release, correct?
As I understand apt, this would mean that
openvino-dev-ubuntu16-yyyy.r.nnn would be the "meta packages to install all the component parts
Have I got things straight?
Shubha R. (Intel) wrote:Dear Markovtsev, Vadim,
New GPG Keys here:
Shubha
I just installed the GPG.PUB file from the link in the updated 2019R3 installation page link and it has the same issue of two keys in one file and apt update is not finding R3
sudp apt-cache search openvino is only showing 2019.2.242 packages
