6574 Discussions
Unable to configure neural computing stick 2 on ubuntu 18.04 openvino 2020.3
KKiran
I am following the instructions given here in the link: https://www.intel.com/content/www/us/en/developer/articles/guide/get-started-with-neural-compute-stick.html
At step 4 when I run the commands given in the above link, I am getting the following error:
"/usr/bin/ld: /usr/lib/x86_64-linux-gnu/libprotobuf.a(arena.o): relocation R_X86_64_TPOFF32 against hidden symbol `_ZN6google8protobuf5Arena13thread_cache_E' can not be used when making a shared object
/usr/bin/ld: /usr/lib/x86_64-linux-gnu/libprotobuf.a(descriptor.o): relocation R_X86_64_PC32 against symbol `_ZNSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaIS5_EED1Ev' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: final link failed: Bad value
collect2: error: ld returned 1 exit status"
also getting the error message "Failed building wheel for onnx"
finally an error message like this is being displayed "Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-_8iyzok9/onnx/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-oevpy1a0-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-_8iyzok9/onnx/
++ error 92
++ local code=1
++ [[ -n '' ]]
++ echo 'Error on or near line 92; exiting with status 1'
Error on or near line 92; exiting with status 1"
My system configuration: Ubuntu 18.04, Openvino 2020 R3.
Thanks in advance.
Peh_Intel
Hi Kiran,
Please try to install the latest protobuf by referring to these instructions.
Besides, instead of running install_prerequisites.sh, perhaps you can try to configure each framework separately.
sudo ./install_prerequisites_caffe.sh
sudo ./install_prerequisites_kaldi.sh
sudo ./install_prerequisites_mxnet.sh
sudo ./install_prerequisites_onnx.sh
sudo ./install_prerequisites_tf.sh
Furthermore, you can refer to our official documentation as provided more information compared to the article.
Peh
Soumya_M_Intel
Hi KKiran,
Thanks for posting your concern on the forum. Since your query is related to the Intel® Neural Compute Stick 2 and OpenVINO™, we are moving this topic to the 'Intel® Distribution of OpenVINO™ Toolkit' community for further assistance.
Have a nice day ahead.
Soumya
Peh_Intel
Hi Kiran,
I was unable to reproduce your issue. Hence, it might require several trials to solve this issue.
There are several steps being carried out when running demo_squeezenet_download_convert_run.sh. I would like to know the error encountered in which part. Perhaps you may point me at which line the demo fails with the error from here.
If the demo fails at the cmake (Line 205), try re-compile with -fPIC.
Modify Line 205 in demo_squeezenet_download_convert_run.sh:
cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_CXX_FLAGS="-fPIC" $samples_path
Peh
KKiran
Dear Peh,
Thank you for taking time to answer. Unfortunately it didn't solve the issue. I am getting error at the time of executing the following command at step 4 given in the link: https://www.intel.com/content/www/us/en/developer/articles/guide/get-started-with-neural-compute-stick.html
cd ~/intel/openvino/deployment_tools/model_optimizer/install_prerequisites/
./install_prerequisites.sh
I've modified as you told above "
I am still getting the same error.
Thank You,
With Regards,
Kiran
Peh_Intel
Hi Kiran,
Peh
KKiran
Dear Peh,
Thanks a lot for taking time and replying for my question. I am happy to inform you that your solution worked.
Peh_Intel
Hi Kiran,
I am glad to hear you are running well now. So, re-install the protobuf manually solved your previous issues?
Peh
KKiran
Dear Peh,
Yes installing protobuf manually and installing all the models one by one solved the issue.
Thank You so much once again for helping.
With Regards
Kiran
Peh_Intel
Hi Kiran,
I was my pleasure to help and thank you for confirming your problem is resolved.
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Peh
