Hi there,
Am trying to convert faster_rcnn_inception_v2_coco_2018_01_28 model to IR using the below command,
python mo.py --input_model /home/workspace/faster_rcnn_inception_v2_coco_2018_01_28/frozen_inference_graph.pb --tensorflow_object_detection_api_pipeline_config /home/workspace/faster_rcnn_inception_v2_coco_2018_01_28/pipeline.config --tensorflow_custom_operations_config_update extensions/front/tf/faster_rcnn_support.json --output_dir /home/workspace/faster_rcnn_inception_v2_coco_2018_01_28
And am facing this error,
Model Optimizer arguments:
Common parameters:
- Path to the Input Model: /home/workspace/faster_rcnn_inception_v2_coco_2018_01_28/frozen_inference_graph.pb
- Path for generated IR: /home/workspace/faster_rcnn_inception_v2_coco_2018_01_28
- IR output name: frozen_inference_graph
- Log level: ERROR
- Batch: Not specified, inherited from the model
- Input layers: Not specified, inherited from the model
- Output layers: Not specified, inherited from the model
- Input shapes: Not specified, inherited from the model
- Mean values: Not specified
- Scale values: Not specified
- Scale factor: Not specified
- Precision of IR: FP32
- Enable fusing: True
- Enable grouped convolutions fusing: True
- Move mean values to preprocess section: False
- Reverse input channels: False
TensorFlow specific parameters:
- Input model in text protobuf format: False
- Path to model dump for TensorBoard: None
- List of shared libraries with TensorFlow custom layers implementation: None
- Update the configuration file with input/output node names: /opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/extensions/front/tf/faster_rcnn_support.json
- Use configuration file used to generate the model with Object Detection API: /home/workspace/faster_rcnn_inception_v2_coco_2018_01_28/pipeline.config
- Operations to offload: None
- Patterns to offload: None
- Use the config file: None
Model Optimizer version: 2019.3.0-408-gac8584cb7
[ ERROR ] -------------------------------------------------
[ ERROR ] ----------------- INTERNAL ERROR ----------------
[ ERROR ] Unexpected exception happened.
[ ERROR ] Please contact Model Optimizer developers and forward the following information:
[ ERROR ] Exception occurred during running replacer "REPLACEMENT_ID (<class 'extensions.front.tf.tensorflow_custom_operations_config_update.TensorflowCustomOperationsConfigUpdate'>)": The function 'update_custom_layer_attributes' must be implemented in the sub-class.
[ ERROR ] Traceback (most recent call last):
File "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/mo/utils/class_registration.py", line 273, in apply_replacements
for_graph_and_each_sub_graph_recursively(graph, replacer.find_and_replace_pattern)
File "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/mo/middle/pattern_match.py", line 58, in for_graph_and_each_sub_graph_recursively
func(graph)
File "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/extensions/front/tf/tensorflow_custom_operations_config_update.py", line 59, in find_and_replace_pattern
replacement_desc.update_custom_replacement_attributes(graph)
File "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/mo/utils/custom_replacement_config.py", line 136, in update_custom_replacement_attributes
raise Exception("The function 'update_custom_layer_attributes' must be implemented in the sub-class.")
Exception: The function 'update_custom_layer_attributes' must be implemented in the sub-class.The above exception was the direct cause of the following exception:
File "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/mo/main.py", line 298, in main
return driver(argv)
File "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/mo/main.py", line 247, in driver
is_binary=not argv.input_model_is_text)
File "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/mo/pipeline/tf.py", line 136, in tf2nx
class_registration.apply_replacements(graph, class_registration.ClassType.FRONT_REPLACER)
File "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/mo/utils/class_registration.py", line 299, in apply_replacements
)) from err
Exception: Exception occurred during running replacer "REPLACEMENT_ID (<class 'extensions.front.tf.tensorflow_custom_operations_config_update.TensorflowCustomOperationsConfigUpdate'>)": The function 'update_custom_layer_attributes' must be implemented in the sub-class.[ ERROR ] ---------------- END OF BUG REPORT --------------
Please tell me why this error's occuring and how to overcome this.
Thank you,
Aditya Nikhil
Please refer to the TensorFlow Specific Conversion Parameters for OpenVINO 2019_R3.1 release that you are using.
You might have probably referred to the documentation for the latest version of OpenVINO on which --tensorflow_use_custom_operations_config is not mentioned. This is because the parameter --tensorflow_use_custom_operations_config is deprecated on the latest release and will be removed in the future releases.
Hi Aditya,
It seems like you are using --tensorflow_custom_operations_config_update parameter instead of --tensorflow_use_custom_operations_config.
Is there any specific reason? If not, please try replacing the specified parameter.
Jaivin
Hey Jaivin,
Thanks for the reply.
So i added update because, it was not recognising the parameter as it is. So i checked with documentation over the website and added update.
Oh yeah my bad..
I specified --tensorflow_custom_operations_config instead of --tensorflow_use_custom_operations_config.
Thank you Jaivin!
