6605 Discussions
Unable to import ONNX: There is no registered "infer" function with op = "Floor"
AKlus
So I'm trying to convert an ONNX model to OpenVINO, and got the following output:
(pystyle) C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer>python mo.py --input_model decoderFHD.onnx
Model Optimizer arguments:
Common parameters:
- Path to the Input Model: C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\decoderFHD.onnx
- Path for generated IR: C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\.
- IR output name: decoderFHD
- Log level: ERROR
- Batch: Not specified, inherited from the model
- Input layers: Not specified, inherited from the model
- Output layers: Not specified, inherited from the model
- Input shapes: Not specified, inherited from the model
- Mean values: Not specified
- Scale values: Not specified
- Scale factor: Not specified
- Precision of IR: FP32
- Enable fusing: True
- Enable grouped convolutions fusing: True
- Move mean values to preprocess section: False
- Reverse input channels: False
ONNX specific parameters:
Model Optimizer version: 2019.1.1-83-g28dfbfd
[ ERROR ] Unexpected exception happened during extracting attributes for node 43.
Original exception message: One/both of widths_scale = None and height_scale = None is not defined for Upsampe node 44.
I do see that the Upsample layer is supported for ONNX models..
The model that gives the error is decoderrand.onnx included in https://github.com/Aeroxander/decodererror
But now I just manually set both variables to 1.0 and that seemed to fix this (hope I didn't destroy the network accuracy, have no idea what the actual values would be).
So now that that problem is semi-fixed, I get this error:
There is no registered "infer" function for node "33" with op = "Floor". Please implement this function in the extensions.
Is the only way to fix this to manually add the Floor function myself?
Shubha_R_Intel
Dear Dearest Klus, Alexander,
Please study the Supported Layers Document.  Your model actually has more than one unsupported layer, for instance Gather, Floor, Cast (see attached image). Model Optimizer had a very un-user-friendly manner of letting you know of this, however. You can get around these unsupported layers by building Custom layers.  I answered a question custom layers IDZ post on how to do that. If you build Custom Layers you can actually get this model to work with OpenVino (both the Model Optimizer and Inference Engine). Hope it helps. Shubha
AKlus
Isn't the floor function just std::floor or isn't it that simple?
Shubha_R_Intel
Dear Klus, Alexander,
Would you mind attaching your ONNX model here ? Or if you'd prefer let me know and I can PM you privately and you can send it to me via PM.
Shubha
AKlus
Shubha_R_Intel
Thanks. This helps a lot. Allow me some time to investigate. Will report back here.
Shubha
Shubha_R_Intel
AKlus
Thank you very much! I'll do my best to add the custom layers!
Shubha_R_Intel
One mistake - Gather and Cast definitely seem to be supported but our documentation doesn't mention it. I have filed a bug on this. I see these files :
deployment_tools\model_optimizer\extensions\front\onnx\cast_ext.py
deployment_tools\model_optimizer\extensions\front\onnx\gather_ext.py
But I don't see a floor_ext.py !
Shubha
B__M
Klus, Alexander,
While converting an ONNX model to OpenVINO I am also running into the "There is no registered "infer" function for node "891" with op = "Floor"." error.
Were you able to add the Floor extension? If so, could you please share your code?
yili__li
I have the same problem like Klus, would you prepare to add the Floor extension?
