How to run a trained model using NCS2?
Rimsha_ch
hi,
i want some help about running a trained model on [RPI+NCS2]. i am new to NCS2 so not sure about this stuff. i tried to understand the generation of .bin and .xml files from guide provided here https://docs.openvinotoolkit.org/latest/_docs_IE_DG_Deep_Learning_Inference_Engine_DevGuide.html but that's just flying over my mind and i get nothing from that. i also visited other sites but not getting it. i wanted to run this model https://github.com/PINTO0309/OpenVINO-YoloV3 on [PRi] , which file exactly i needed to convert into .bin and .xml and how?
if you can help me with command line arguments so i can get something and able to use NCS2.
Luis_at_Intel
Hi @Rimsha ch,
Thanks for contacting us. There are some webinars available that overviews the essentials of the OpenVINO™ toolkit, you can find those webinar series here. I hope these videos help you get a bit more understanding about what IR format is (.bin and .xml).
As far as your question goes in regards of PINTOS' repo, you will first need to install OpenVINO™ toolkit on your Raspberry Pi board (if that is the route you want to go). He provides some steps in the repo under "Environment construction procedure" section, Option #2, or you can take a look at OpenVINO™ documentation for Raspbian here.
Once you have installed the OpenVINO™ toolkit and verified the installation, you will need to clone PINTOS' repository using:
cd ~/ git clone https://github.com/PINTO0309/OpenVINO-YoloV3.git
Navigate to this directory:
~/OpenVINO-YoloV3/lrmodels/tiny-YoloV3/FP16
Run the download_tiny-yolov3lrFP16.sh script to download the .xml and .bin files, as far as I can tell there is no need to convert any files to IR format as the script downloads them for you.
./download_tiny-yolov3lrFP16.sh
Then you can proceed to run the python sample for the NCS device with:
python3 openvino_tiny-yolov3_MultiStick_test.py -numncs 1
Note: Make sure you have a USB camera and your NCS device plugged in, otherwise may throw errors.
Hope you have found this helpful, let us know if you have any additional questions.
@Luis_at_Intel​
Luis_at_Intel
Hi @Rimsha ch,
@Luis_at_Intel​
Rimsha_ch
That helped me!! thanks you very much
