Unable to import cv2 on Mac
Celi__Joseph
I just installed the latest OpenVINO toolkit for Mac.  I'm getting the following error
[setupvars.sh] OpenVINO environment initialized
$ python
Python 3.6.1 (default, Sep 24 2019, 10:11:07)
[GCC 4.2.1 Compatible Apple LLVM 10.0.1 (clang-1001.0.46.4)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import cv2
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
ImportError: dlopen(/opt/intel/openvino_2020.1.023/python/python3/cv2.so, 2): Library not loaded: @rpath/libopencv_ml.4.2.dylib
  Referenced from: /opt/intel/openvino_2020.1.023/python/python3/cv2.so
  Reason: image not found
Celi__Joseph
I thought I figured it out but was wrong so I am deleting what I thought fixed the issue.
Maksim_S_Intel
Please check if your installation is complete, does file "/opt/intel/openvino_2020.1.023/opencv/lib/libopencv_ml.4.2.dylib" exist?
Celi__Joseph
The file does exist but not in that directory.  This could be due to the fact that I tried all 3 installation types and the last installation type was "user"
Joseph-Celi-MBP:lib josephceli$ pwd
/Users/josephceli/intel/openvino_2020.1.023/opencv/lib
Joseph-Celi-MBP:lib josephceli$ ll libopencv_ml.4.2.dylib
lrwxrwxr-x  1 josephceli  staff  24 Jan 27 10:56 libopencv_ml.4.2.dylib -> libopencv_ml.4.2.0.dylib
Maksim_S_Intel
So you have to activate environment for installation in user directory: ". /Users/josephceli/intel/openvino_2020.1.023/bin/setupvars.sh"
Celi__Joseph
Maksim,
Yes, I had been doing that.
Joseph-Celi-MBP:opencv josephceli$ . /Users/josephceli/intel/openvino_2020.1.023/bin/setupvars.sh
Joseph-Celi-MBP:opencv josephceli$ python get_ver.py
  File "get_ver.py", line 1, in <module>
    import cv2
ImportError: dlopen(/Users/josephceli/intel/openvino_2020.1.023/python/python3/cv2.so, 2): Library not loaded: @rpath/libopencv_ml.4.2.dylib
  Referenced from: /Users/josephceli/intel/openvino_2020.1.023/python/python3/cv2.so
Maksim_S_Intel
I can not reproduce the issue:
$ . intel/openvino_2020.1.023/bin/setupvars.sh
$ python3
Python 3.7.3 (default, Jun 19 2019, 07:38:49)
[Clang 10.0.1 (clang-1001.0.46.4)] on darwin
>>> import cv2
What is your OS version? Check LD_LIBRARY_PATH and DYLD_LIBRARY_PATH environment variables contents, at least one of them should contain path to opencv/lib directory. Check sizes of installed files.
Celi__Joseph
macOS Mojave - Version 10.14.6
checking library paths now and will report back
Celi__Joseph
Joseph-Celi-MBP:~ josephceli$ . /Users/josephceli/intel/openvino_2020.1.023/bin/setupvars.sh
Joseph-Celi-MBP:~ josephceli$ echo $LD_LIBRARY_PATH
/Users/josephceli/intel//openvino_2020.1.023/opencv/lib:/Users/josephceli/intel//openvino_2020.1.023/deployment_tools/ngraph/lib:/Users/josephceli/intel//openvino_2020.1.023/deployment_tools/inference_engine/external/mkltiny_mac/lib:/Users/josephceli/intel//openvino_2020.1.023/deployment_tools/inference_engine/external/tbb/lib:/Users/josephceli/intel//openvino_2020.1.023/deployment_tools/inference_engine/lib/intel64:
Joseph-Celi-MBP:~ josephceli$ echo $DYLD_LIBRARY_PATH
Joseph-Celi-MBP:~ josephceli$ find . -name libopencv_ml.4.2.dylib 2>/dev/null
./intel/openvino_2020.1.023/opencv/lib/libopencv_ml.4.2.dylib
Joseph-Celi-MBP:~ josephceli$ pwd
/Users/josephceli
Max_L_Intel
Hello Joseph.
Can you please try the workaround from this thread - https://github.com/opencv/opencv/issues/14353
Celi__Joseph
Just noticed this last update.  @Max - I will try the workaround and report back.
Celi__Joseph
@Max - I appreciate the link but am still unsure how to take the information from those links and apply it to my machine to get around the fact that the OpenCV dynamic link library cannot be found at runtime.  While the link above describes a similar problem from the Java environment it certainly appears to be exactly what I am seeing.  I tried to manually update my environment, using the following snippet from the links provided above
if sys.platform == 'darwin': # https://github.com/opencv/opencv/issues/14351
if env is None:
env = os.environ.copy()
if 'DYLD_LIBRARY_PATH' in env:
env['OPENCV_SAVED_DYLD_LIBRARY_PATH'] = env['DYLD_LIBRARY_PATH']
I still see the same error
  File "multi_camera_multi_person_tracking.py", line 22, in <module>
    import cv2 as cv
Thanks for your support
Max_L_Intel
Hi Joseph.
Can you please try it with "python3" alias instead of just "python"? Or you could also try upgrading python over to 3.7 version.
I see the same behavior on my machine with "python" as python 2.7, but everything's fine with "python3" as python 3.7.
Best regards, Max.
