I'm unable to load the Intel model action-recognition-0001-decoder to NCS, either v1 or v2. I'm using the latest release R2 (2019.2.242). However, it can be successfully loaded to CPU (intel core i5) as well as GPU (Gefore GTX 950M).
Here is my minimum (not) working example:
# load_action_decoder.py import argparse import os import sys from openvino.inference_engine import IENetwork, IEPlugin if __name__ == '__main__': parser = argparse.ArgumentParser() parser.add_argument('-d', '--device', type=str, default='MYRIAD') parser.add_argument('-m', '--model-xml', type=str) ARGS = parser.parse_args() model_xml = ARGS.model_xml model_bin = os.path.splitext(model_xml)[0] + '.bin' net = IENetwork(model=model_xml, weights=model_bin) net.batch_size = 1 plugin = IEPlugin(device=ARGS.device) exec_net = plugin.load(network=net)
and the error message:
$ python3 load_action_decoder.py --device=MYRIAD --model-xml=/tmp/intel_models/242/Transportation/action_recognition/resnet34_vtn/kinetics/decoder/dldt/FP16/action-recognition-0001-decoder.xml Traceback (most recent call last): File "load_action_decoder.py", line 19, in <module> exec_net = plugin.load(network=net) File "ie_api.pyx", line 551, in openvino.inference_engine.ie_api.IEPlugin.load File "ie_api.pyx", line 561, in openvino.inference_engine.ie_api.IEPlugin.load RuntimeError: AssertionFailed: inputs.size() == 3
I also tried the previous release R1 (2019.1.144), however, for all device types MYRIAD, CPU, and GPU, it gives me segmentation fault:
python3 load_action_decoder.py --device=MYRIAD --model-xml=/tmp/intel_models/144/Transportation/action_recognition/resnet34_vtn/kinetics/decoder/dldt/action-recognition-0001-decoder-fp16.xml Segmentation fault (core dumped)
Note that this time I used the model downloaded with R1 downloader.py.
Please help!
P.S: the same error for model driver-action-recognition-adas-0002-decoder.
Dear Pan, Alan,
OpenVino has the Action Recognition Demo . Have you tried it on MYRIAD ? Please read the online document and study the example command-line. Let me know if it works for you.
Shubha
Hi Shubha,
Thanks for the pointer. Yes, the demo itself works. However, by taking a closer look I realized that the demo is actually "cheating":
# /opt/intel/openvino_2019.2.242/deployment_tools/open_model_zoo/demos/python_demos/action_recognition/action_recognition.py#L89 decoder_target_device = "CPU" if args.device != 'CPU': encoder_target_device = args.device else: encoder_target_device = decoder_target_device
It forces the decoder to use CPU. The same error occurs if I use "MYRIAD" for decoder_target_device as well.
There are some other differences in the demo, such as using IECore instead of IEPlugin, and calling ie.set_config, but they don't seem to help as long as the decoder actually uses MYRIAD.
Please advise.
Thanks!
Alan
Dear Pan, Alan,
Ha ha. OK I see what you mean. I wonder if the decoder uses some layers unsupported by MYRIAD ? Please look at the Supported Devices Doc . Can you kindly look at the generated IR for action-recognition-0001-decoder and see if there is an unsupported layer ? If you can't find one, then this is a bug. Whomever wrote the Action Recognition Demo must have "cheated" because he knew that there was a limitation with using the MYRIAD as a detector.
Let me know,
Shubha
Hi Shubha,
I extracted the layer types from the decoder's xml file, and they all seem to be supported by VPU (except for the Input layer):
$ cat /tmp/intel_models/242/Transportation/action_recognition/resnet34_vtn/kinetics/decoder/dldt/FP16/action-recognition-0001-decoder.xml | grep -oP '(?<=type=").*(?=")' | sort | uniq Const Convolution Eltwise FullyConnected GEMM Input Permute Pooling Power ReLU Reshape SoftMax Tile
I also tried to programmatically find unsupported layers:
plugin = IEPlugin(device=ARGS.device) # MYRIAD supported_layers = plugin.get_supported_layers(net) not_supported_layers = [l for l in net.layers if l not in supported_layers] for l in sorted(not_supported_layers): print('{:<30}\t{}'.format(l, net.layers.type))
Some of them did show up, including Const and GEMM types (see below). However, both Const (?!) and GEMM are listed as "supported" by VPU from the documentation. Either the documentation is wrong, or the Python API is wrong, or something else.
0 Input 218/Output_0/Data__const Const 219/Output_0/Data__const Const 220/Output_0/Data__const Const 225/Output_0/Data__const Const 226/Output_0/Data__const Const 227/Output_0/Data__const Const 232/Output_0/Data__const Const 233/Output_0/Data__const Const 234/Output_0/Data__const Const 239/Output_0/Data__const Const 240/Output_0/Data__const Const 241/Output_0/Data__const Const 247/Output_0/Data_/copy_const Const 249/Output_0/Data_/copy_const Const 290 GEMM 298 GEMM 306 GEMM 315 GEMM 339 GEMM 395 GEMM 403 GEMM 411 GEMM 420 GEMM 444 GEMM 500 GEMM 508 GEMM 516 GEMM 525 GEMM 549 GEMM 605 GEMM 613 GEMM 621 GEMM 630 GEMM 654 GEMM
Is there a workaround or configuration that I can do? If not, when do we expect it to be fixed?
Alan
Dear Pan, Alan,
I think you may have found a bug. I have PM'd you to get your version of the action recognition decoder script where the target decoder device is NCS.
Please send it to me and I will file a bug on your behalf.
You can also attach your script as a *.zip to this forum ticket.
Sorry for the trouble !
Shubha
Dear Pan, Alan,
Thank you for your cooperation (by sending me your Python script which demos the issue) ! I have filed a bug on your behalf.
Sincerely,
Shubha
Dear Pan, Alan
You'll be happy to know that this issue has been fixed in OpenVino R3.
Thanks for your patience !
Shubha
![](/skins/images/8C80966F940F80D854AEDDDACECA968C/responsive_peak/images/icon_anonymous_message.png)
