Unable to run smart classroom sample on VPU
Adithya_N_Intel
Getting the below error while trying to run smart classroom demo with VPU on docker.
[ ERROR ] [ NOT_FOUND ] DVN_BATCH_ENABLED key is not supported for VPU
Openvino 2019 R1
Models used: face-detection-adas-0001, headpose-estimation-adas-0001, emotions-recognition-retail-0003, face-reidentification-retail-0095.
When googled with error, read somewhere that VPU has limited support for models. Could you confirm if that is the cause for this issue?
Please look into it and resolve.
TIA
Luis_at_Intel
The models you have listed based on the documentation here have support for the Myriad plugins.
  1. face-detection-adas-0001
  2. head-pose-estimation-adas-0001
  3. emotions-recognition-retail-0003
  4. face-reidentification-retail-0095
To make sure the models were working on the Myriad plugin, I tested the first 3 models using the Interactive Face Detection Demo (on a Windows 10 environment and a USB cam as input) and they seem to work as expected.
Example:
<path-to>\inference_engine_samples_build\intel64\Release\interactive_face_detection_demo.exe -i cam -m "<path-to>\face-detection-adas-0001-fp16.xml" -m_ag "<path-to>\age-gender-recognition-retail-0013-fp16.xml" -m_hp "<path-to>\head-pose-estimation-adas-0001-fp16.xml" -m_em "<path-to>\emotions-recognition-retail-0003-fp16.xml" -d MYRIAD -d_ag MYRIAD -d_em MYRIAD -d_hp MYRIAD
After this I went ahead and tested the Smart Classroom Demo and for me it worked using the face-detection-adas-0001 and the face-reidentification-retail-0095 models as shown by the command below. May I ask how exactly is it that you are running the demo? If you can provide more details on your environment and steps followed to reproduce I can try to help resolve your issue. I hope you have found this information helpful, please let me know if you have any other questions.
Example:
<path-to>\inference_engine_samples_build\intel64\Release\smart_classroom_demo.exe -m_act "<path-to>\person-detection-action-recognition-0005-fp32.xml" -m_fd "<path-to>\face-detection-adas-0001-fp16.xml" -m_reid "<path-to>\face-reidentification-retail-0095-fp16.xml" -fg "C:\Users\user\Documents\Intel\OpenVINO\openvino_models\faces_gallery.json" -i cam -d_act CPU -d_fd MYRIAD -d_reid MYRIAD
@Luis_at_Intel
AamnaIqra_S_Intel
Hi Luis
Thanks for your reply
We tried to run smart classroom demo in ubuntu 16.04.1
We have faced the same issue as mentioned above
Please find the attached png with the same.
Aamna
Shubha_R_Intel
Dear Syed, Aamna Iqra,
The main difference between what Luis did and what you tried is that your d_fd is HDDL. Can you try again with the latest OpenVino Release 2019R1.1 (released just this week) ? If you still suffer the same problem I will file a bug on your behalf.
Sorry for the inconvenience !
Shubha
