Unable to select Myriad in DL Workbench
AshishPapanai
Myriad is available as a non-selectable option; I've tried to follow the solution mentioned in link.But that doesn't work either, any help would be useful.
Zulkifli_Intel
Hello Ashish Papanai,
Which OS did use to run the DL Workbench? For your information, Windows, Linux and MacOS support CPU targets. GPU, Intel Neural Compute Stick 2 and Intel Vision Accelerator Design with Intel Movidius VPUs are supported only for Linux.
You can refer to Recommended Requirements for DL Workbench to ensure all features are usable.
Sincerely,
Zulkifli
AshishPapanai
Hello @Zulkifli_Intel
I am using Ubuntu 20.04 LTS to run DL Workbench.
Zulkifli_Intel
Try running these two commands to see if the VPU can be selected or not:
python3 -m pip install -U openvino-workbench
openvino-workbench --image openvino/workbench:2022.1 --enable-myriad
Sincerely,
Zulkifli
AshishPapanai
Hi @Zulkifli_Intel
I am still not able to select VPU.
Zulkifli_Intel
For the Linux version, only Ubuntu 18.04 LTS version is supported and has been validated.
You can get the related information here:
https://docs.openvino.ai/2022.1/workbench_docs_Workbench_DG_Prerequisites.html
I would suggest you use DL Workbench in Ubuntu 18.04 LTS environment if you want to use MYRIAD plugin.
Sincerely,
Zulkifli
Zulkifli_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Sincerely,
Zulkifli
