I tried to run inference of Mask R-CNN Inception ResNet V2 1024x1024 from Tensorflow2 Model Zoo. I am using the following command to convert the tensorflow model.
mo --saved_model_dir "mask_rcnn_inception_resnet_v2_1024x1024_coco17_gpu-8/saved_model" --transformations_config "/root/sharedfolder/dent_damage_det/mask_rcnn_support_api_v2.0.json" --tensorflow_object_detection_api_pipeline_config "mask_rcnn_inception_resnet_v2_1024x1024_coco17_gpu-8/pipeline.config" --output_dir "/root/sharedfolder/dent_damage_det/mrcnn_zoo" --input_shape [1,1024,1024,3]
The model got converted successfully. While running inference on the converted model I am getting this error:
--------------------------------------------------------------------------- RuntimeError Traceback (most recent call last) <ipython-input-68-f922978d5286> in <module> 7 request = compiled_model.create_infer_request() 8 input_image = np.zeros((1, 1024, 1024,3)) ----> 9 request.infer(inputs={input_layer.any_name: input_img}) /opt/intel/openvino/python/python3.6/openvino/runtime/ie_api.py in infer(self, inputs) 108 """ 109 return super().infer( --> 110 {} if inputs is None else normalize_inputs(inputs, get_input_types(self)) 111 ) 112 RuntimeError: Proposal operation image info input must have positive image height and width.
Code to run inference:
ie_core = Core()
model = ie_core.read_model(model=model_path, weights=model_weights_path)
compiled_model = ie_core.compile_model(model=model, device_name="CPU")
input_layer = next(iter(compiled_model.inputs))
output_layers = list(compiled_model.outputs)
Hello Vishnuj
The Python code that you shared appears to be incomplete. You can refer to Inference Pipeline for guidance.
For your information, Intel Open Model Zoo has two mask_rcnn models:
Both of these models can be run with Object Detection Mask R-CNNs Segmentation C++ Demo.
Sincerely,
Zulkifli
Hello Vishnuj,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Sincerely,
Zulkifli
