- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
So I was told earlier by the community to open a pull request ( https://github.com/openvinotoolkit/openvino/pull/31297 ) for my patch which I did and then I was told by the pull request reviewers to open an issue for this which I also did but got the same response in the end after waiting for more than 6 months now. Here's the link to the issue: https://github.com/openvinotoolkit/openvino/issues/33137
I am sure there are many ways to locate logs of committed files in the Intel Developer Cloud but they claim everything has been deleted and nothing can be recovered. Are they really saying that they have deleted all their previous data without even taking snapshots fof the drive or creating physical backups? I don't think so. They also said since the intel solutions have been discontinued, they also deleted the solution file which I had downloaded locally on my laptop. This is completely unacceptable, unethical and a breach of trust from Intel. Please advise what can be done now...
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Sid5,
Thank you for sharing your concerns. I’d like to clarify a few points to ensure the situation is accurately represented.
Regarding the OpenVINO GitHub workflow, you were advised to submit a pull request with the actual code changes so that maintainers could review and validate the fix. While a PR was opened, it did not include the corresponding code changes. Without concrete changes in the repository, maintainers cannot review, approve, or merge a contribution. Opening an issue or PR alone is not sufficient without the associated code.
With respect to Intel Developer Cloud (IDC), the service has been formally discontinued, and the infrastructure fully decommissioned. In accordance with Intel’s privacy and compliance requirements, customer environments and data stored within IDC were sanitized as part of the shutdown process. As a result, there is no capability to access historical logs, snapshots, or recover files from the former IDC environment.
It is also important to clarify that Intel does not have the ability to access or delete files from a user’s personal device. Any files downloaded locally would remain under the user’s control, and Intel systems cannot remove data from a personal laptop.
We understand this is a frustrating outcome, especially given the time invested. However, without the code being available in the GitHub repository, there is no technical basis for review or validation. If you are able to re‑implement the fix and submit the corresponding code changes, the OpenVINO maintainers will be able to review it through the normal contribution process.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I have proof (email) where Intel told me about the file that they deleted from my local machine, if you want I can show it as well.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Sid5,
Thank you for your response.
I understand that you may not be convinced by the explanation provided. However, I want to be clear and consistent with our position.
Intel Developer Cloud (IDC) has been formally discontinued, and the infrastructure fully decommissioned. In accordance with Intel’s privacy, security, and compliance requirements, customer environments and data hosted on IDC were sanitized as part of the shutdown process. As a result, there is no technical capability to access historical logs, snapshots, or recover files from the former IDC environment.
Regarding notifications, service lifecycle communications are handled through official channels associated with the program or platform at the time. At this stage, regardless of prior notifications, the technical reality remains unchanged: the IDC systems no longer exist, and data recovery is not possible.
With respect to your statement about a local file being deleted, Intel does not have the ability to access or remove files from a customer’s personal machine without explicit authorization. We are not able to act on or validate claims related to local system changes.
At this point, we have provided all the information available, and there is no further action that can be taken on this request. Any future progress on OpenVINO contributions would require the code to be re‑implemented and submitted directly through GitHub for review.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
@Sid5 The fact that you've lost your changes seems unreal, giving that we're talking about GitHub backend being involved at least for the PR. Have you attempted to use GitHub API to get the full history of that PR to see if there's any indication when the files went missing?
And it sounds like you made your original code changes in an Intel hosted environment on IDC, which is gone, and you don't have any local copies of that code?
My memory is vague on this, but I remember reading your original thread last year on these forums about your contribution and it was awaiting a review; apparently someone at Intel was away and they were going to review it after they came back or some such. I remember looking at your PR, but I cannot say with certainty today that I looked at the code. I do remember being thoroughly impressed that someone from outside Intel (true?) understood the code base so well and could make a significant contribution.
I wish you all the best in trying to recover your contribution.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
@codefarmer It's not unreal, before I could upload the changes to github, my SSD got corrupted and I had to replace it with a new one. Ever since, I have been trying to recover my SSD data but still unable to do so due to unforeseen circumstances. The thread you read is exactly why I posted this because of all the delayed/vague responses from Intel. Furthermore, it is no big deal for me to understand any software stack end to end and implement significant solutions and I do not think that Intel simply deleted their whole IDC database entirely without any backup to shift to a new one. It seems like they are lying knowingly but that's just me who really knows what's the real truth. I didn't just resolve the issue, I also integrated it with Intel stack at the time but that also seems to be deleted by them apparently. Anyways, thanks for your comment and interest in my PR, I really appreciate it.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
