6589 Discussions
Unknown command line flag 'alsologtostderr'
I tried to run mobilenets example in ncapzoo whith description given in https://github.com/movidius/ncappzoo/blob/master/tensorflow/mobilenets/README.md.
It fails when i try to run "make" command with the following error:
` - "nception_v3_2016_08_28.tar.gz" saved [100885009/100885009]
(cd model/v3; tar -xvf inception_v3_2016_08_28.tar.gz;)
inception_v3.ckpt
TF_MODELS_PATH is /home/pi/Development/tensorflow/models
Exporting GraphDef file…
(cd model/v3; python3 /home/pi/Development/tensorflow/models/research/slim/export_inference_graph.py \
--alsologtostderr \
--model_name=inception_v3 \
--batch_size=1 \
--dataset_name=imagenet \
--image_size=299 \
--output_file=inception_v3.pb;)
FATAL Flags parsing error: Unknown command line flag 'alsologtostderr'
Pass --helpshort or --helpfull to see help on flags.
Makefile:72: recipe for target 'export' failed
make: *** [export] Error 1'
@GoldenWings It sounds like you may be trying to run the make commands with Tensorflow models on the Raspberry Pi. This a known issue with NCSDK version 1.12. You can try generating the graph files on your PC and try running the examples using the python3 command followed by the app's python script name. Please refer to the release note # 2 on the release notes page.
i cant generate the graph on my pc, because i am running linux mint and when i try to generate the graph it says
/bin/sh: 1: mvNCProfile: not found
Makefile:96: recipe for target 'profile' failed
make: *** [profile] Error 127
Any recommendation?
@GoldenWings Maybe generate the graph files on a VM and then transfer over to the pi?
