6597 Discussions
Can I output the value of Movidius' middle layers?
How can I output the value of Movidius' middle layers? Thanks.
@miily If you are talking about seeing the intermediate results from your model, you can use this using the -on option for mvNCCheck.
Let’s assume your network architecture is as follows:
Input - Data
conv1 - Convolution Layer
pooling1 - Pooling Layer
conv2 - Convolution Layer
pooling2 - Pooling Layer
Softmax - Softmax
You can use the following command: mvNCCheck user_network -w user_weights -in input -on conv1 to check the output from the conv1 layer.
For more information on mvNCCheck, please refer to this blog.
