Upgrading older IR models to v10
dangu
Question: is it possible to upgrade older OpenVINO IR models (xml/bin) to v10? (either using the model optimizer or the API)
Thanks!
JAIVIN_J_Intel
It is recommended to use OpenVINO pre-trained models that are available for corresponding OpenVINO versions to avoid incompatible issues.
However, Model Optimizer could be used to generate deprecated IR to work with previous versions of the Inference Engine but not for future versions.
