Use OpenVino in Debian Stretch
cidervul
I am starting with openvino and NCS2 and I am wondering if it could be possible to use openvino in debian stretch.
I know that, officially, only ubuntu and centos is supported but I don't know why it could not be possible to make it working with debian stretch.
Thanks in advance.
Shubha_R_Intel
Dear Onemikeoscar,
yes we do indeed support raspbian stretch. Please check the following online documentation.
https://github.com/opencv/opencv/wiki/Intel%27s-Deep-Learning-Inference-Engine-backend#raspbian-stretch
Shubha
cidervul
Shubha R. (Intel) wrote:
Dear Onemikeoscar,
Shubha
Yes, but, if i try to install it in debian with the official installer a warning message appears telling me that it debian is not supported.
Jitendra_S_Intel
I have same request. Installing OpenVINO on x86 Debian Stretch machine.
Shubha_R_Intel
Dear Onemikeoscar and jay07920,
unfortunately at this time we do not support Debian Stretch. We may support it in the future, however, based on customer demand. You are welcome to build the infrastructure to support Debian Stretch yourself - after all OpenVino is open source ! Check out our dldt github :
https://github.com/opencv/dldt.git
And thanks for your interest in OpenVino !
Shubha
om77
Actually Ubuntu 16.04 binaries should work on Debian Stretch.
The job to be done here is mostly related to changing install scripts.
Maksim_S_Intel
Probably you can trick installer by replacing /etc/lsb-release file temporarily to the one from Ubuntu 16 or 18.
om77
Debian doesn't have /etc/lsb-release. It uses /usr/bin/lsb_release instead.
I would start here from copying /etc/lsb-release from Ubuntu 16.04 to Debian Stretch and review all the scripts containing "lsb-release".
May be the best way would be is to copy /etc/lsb-release from Ubuntu 16.04 system to Debian Stretch system into folder /opt/intel.
And next (before installation OpenVino) to change in OpenVino install scripts "/etc/lsb-release" to "/opt/intel/lsb-release".
yang__jun
Fake a /etc/lsb-release file with the following content, and you will be able to fool the installer into thinking your system is a Ubuntu. After installation, you can delete the /etc/lsb-release file.
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION="Ubuntu 16.04 LTS"
