Good Day!
Can you please let me know,if I can use GNA PLUGIN (https://docs.openvinotoolkit.org/latest/openvino_docs_IE_DG_supported_plugins_GNA.html) in Intel core i3-1115g4 NUC for real time video analytics (Object Detection using OPENCV & CAFFE-SSD MOBILENET) applications?
as I have read, all of Intel's 11 gen machines are compatible with GNA Plugin.
Guru
Hi Guru,
Yes, you're right. Intel® Core™ i3-1115G4 Processor, which is an 11th Generation Intel® Core™ i3 Processor, is supported for GNA plugin.
However, due to specifics of hardware architecture, Intel® GNA only supports a limited set of layers. For example, you should not expect the GNA Plugin to run computer vision models, except those specifically adapted for the GNA Plugin, because the plugin does not fully support 2D convolutions.
More information is available at the following link:
For the list of supported layers, see the GNA column in the following link:
Munesh
Your response resolved my issue.
Hi Guru,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Munesh
