6616 Discussions
Using Inference Engine ReadNetwork method to load models from memory
Subtle
I want OpenVINO’s inference engine to load models from memory (not from a file path).
For this I am using  CNNNetwork ReadNetwork(const std::string& model, const Blob::CPtr& weights) function.
I need help regarding how can i create Blob::CPtr weights from weights.bin file. I am using OpenVINO 2021.4 version and OS is Ubuntu 20.04 LTS.
Thank you
Peh_Intel
Hi Subtle,
You can create Blob objects using constructors with InferenceEngine::TensorDesc. You can refer to Inference Memory Primitives (C++) for more information.
Besides, I also found that someone shared his way to load model from memory in the previous post which may be helpful for you.
Peh
Peh_Intel
Hi Subtle,
Peh
Subtle
Hi Peh,
Thanks for reply.
I am creating Blob objects using constructor  TensorDesc(const Precision& precision, const SizeVector& dims, Layout layout) . For my use case i need to keep Precision::UNSPECIFIED and Layout::ANY, I want to understand more about const SizeVector& dims, what should i keep for this parameter, if i am keeping Layout::ANY.
Thank you
Peh_Intel
Hi Subtle,
There is nothing special for the layout set as “ANY”. The parameters for the dimension still need to set based on the model in the supported format (InferenceEngine::Layout::NCDHW, InferenceEngine::Layout::NCHW, InferenceEngine::Layout::NC, InferenceEngine::Layout::C).
Peh
Subtle
Hi Peh,
Thanks a lot for reply.
I got the point.
Thanks & Regards
Subtle
Peh_Intel
Hi Subtle,
This thread will no longer be monitored since we have provided answers. If you need any additional information from Intel, please submit a new question.
Peh
