Regarding Openvino Deeplearning Workbench
Aurjay
I have proxy issues  and cannot access models in my computer. Please let me know how to configure the proxies correctly .
I have attached the log file for your convinience.
Please let me know what the problem is as this issue is blocking my work progress.
Peh_Intel
Hi Aurjay,
You can use the installation form to specify proxy for DL Workbench container. Enter your proxy at the “Use HTTP Proxy” and “Use HTTPS Proxy”. The command to start DL Workbench with proxy will show up.
If this does not help, perhaps you can try to import the model from local file as the network connectivity issues caused the model failed to download. This means you can prepare the models first and then upload the model to DL Workbench instead of downloading the model through DL Workbench.
Peh
Peh_Intel
Hi Aurjay,
This thread will no longer be monitored since we have provided suggestions. If you need any additional information from Intel, please submit a new question.
Peh
