6586 Discussions
Using OpenVINO with GPU reboot automatically the system
Truong__Dien_Hoa
New Contributor II
I have problem on using OpenVINO with GPU (I use the UP squared board, GPU Intel Gen 9). Very often my system reboot automatically when I execute the inference with GPU. Not always but very often. I thought that it maybe because of overheating but today it reboot directly from the first execution (the board isn't hot at all).
I have just updated OpenVINO to the last release and the problem is still there,
Someone can help me on this,
Thank you so much and best regards,
Truong__Dien_Hoa
New Contributor II
[Update] it's likely because of overheating. I'm using a cooling fan and now it doesn't reboot anymore. When it works, everything is perfect. I removed the fan and now, even at 75°C, it works (before, it can be reboot at 65°C).
Anyone know about this problem ? In my opinion, 65°C is not very hot right ?
Thanks and best regards,
Truong__Dien_Hoa
New Contributor II
[Update] It is not really related to the temperature. I minimize the code so that you can track where the problems is as below.
import cv2
import numpy as np
import time
from openvino.inference_engine import IENetwork, IEPlugin
net = IENetwork(model='/home/k/face-detection-retail-0004.xml', weights='/home/k/face-detection-retail-0004.bin')
plugin = IEPlugin(device="GPU")
exec_net = plugin.load(network=net)
def _preprocess_face(img, shape=(300,300)):
    origin_shape = img.shape
    img_processed = cv2.cvtColor(img, cv2.COLOR_RGB2BGR)
    img_processed = cv2.resize(img_processed, (shape[0], shape[1]))
    img_processed = img_processed.transpose((2, 0, 1))
    return img_processed
image = cv2.imread('/home/k/_.jpg')
for i in range(100):
    img = cv2.cvtColor(image, cv2.COLOR_BGR2RGB)
    img = _preprocess_face(img)
    start = time.time()
    res = exec_net.infer({'data': img})
    print(time.time()-start)
The output I got is:
$ python gpu.py
0.017605304718017578
0.014819860458374023
It ran 2 times then the system reboot. I have tried many differents things that I can imagine: I use different model, run as asynchronous, synchronous but the problems is always there. sometimes it reboots directly from the 1 try, sometimes after several try.
I would really appreciate if someone can help me on that.
The model I downloaded from Openvino pretrained model for face detection
