Using both Intel GPU and VPU simultaneously
YAP__KELVIN
I installed your latest OpenVino R2020.2 version and have tested out some of your inference engine demos. However, I have a few queries as followed :
(1) Am I able to run the object detection inference on the Intel GPU and simultaneously run a tracker (i.e. KLT tracker) on the return detected object on VPU?
(2) When we run the model optimizer on a model, can we actually know what are the unnecessary layers that are actually being removed during the optimization process?
Kelvin
Munesh_Intel
Hi Kelvin,
You can try modifying the demo with the tracker of your choice and validate it.
Additionally, it is also important to note that specific components of a demo don’t support different plugins. However, you can also explore and validate them on your end as well.
For your second question, you can use -pc option to enable per-layer performance report.
More information is available at the following page:
https://docs.openvinotoolkit.org/2020.3/_demos_object_detection_demo_ssd_async_README.html#running
Additionally, you can also run the Benchmark C++ tool, which outputs the number of executed iterations, total duration of execution, latency, throughput and statistics report as well.
https://docs.openvinotoolkit.org/2020.3/_inference_engine_samples_benchmark_app_README.html
Munesh
