6583 Discussions
VirtualBox 6 W: [ 0] ncDeviceOpen:527 ncDeviceOpen() XLinkBootRemote returned error 3
Hi
I am running my compute stick 2 from Ubuntu 16.04 in a Virtalbox 6 VM. I am unable to compile the ncsdk examples, nor run any of my own code I am trying to develop.
During the example compile I get:
Eliminate layers that have been parsed as NoOp
Fusing Pad and Convolution2D
Fusing Scale after Convolution or FullyConnect
Fusing standalone postOps
Fusing Permute and Flatten
Fusing Eltwise and Relu
Fusing Concat of Concats
Evaluating input and weigths for each hw layer
Network Input tensors ['data#24']
Network Output tensors ['prob#38']
Blob generated
[Error 7] Toolkit Error: USB Failure. Code: Error opening device
Makefile:64: recipe for target 'profile' failed
make[2]: *** [profile] Error 255
make[2]: Leaving directory '/home/msupra/Downloads/ncsdk/examples/caffe/AlexNet'
Makefile:12: recipe for target 'AlexNet' failed
make[1]: *** [AlexNet] Error 2
make[1]: Leaving directory '/home/msupra/Downloads/ncsdk/examples/caffe'
Makefile:12: recipe for target 'caffe/.' failed
make: *** [caffe/.] Error 2
When I run my own "hello world" app, I get:
python3 helloworld.py
1 neural compute devices found!
Device name: 2-ma2480
Traceback (most recent call last):
File "helloworld.py", line 15, in
device.open()
File "/usr/local/lib/python3.5/dist-packages/mvnc/mvncapi.py", line 446, in open
raise Exception(Status(status))
Exception: Status.ERROR
The device is found, but as soon as I want to open the device, it fails. I have been trying for three days now to get the stick to work, but with no luck. Any help will be appreciated.
Hi @msupra
The software kit that is compatible with your NCS2 is OpenVINO. The NCSDK (v1/v2) is only compatible with the NCS1. Here is the link to install OpenVINO. If you have any questions with OpenVINO and the NCS2, please post them here so that we can better assist you!
Sahira
