Virtualbox NCS 2 with OpenVino (OSX Host)
Mansfeld__Eike
There are several guides to get NCS up and running under Ubuntu (Guest) on a OSX Host using VirtualBox 5.22. However NCS 2 seems not to work in that context. I tried everything mentioned in the forums, but could not get the stick connected properly. After running the setup example, the device switches back to 'Intel VCS Loopback device'. The example terminates with
[ ERROR ] Can not init USB device: NC_DEVICE_NOT_FOUND
Any idea? Did anyone get the NCS-2 working with VirtualBox on OSX?
Eike
Deblauwe__Tom
I am stuck with the same, did you find out how to do it in the meantime?
Best regards
