Visualize IR model
V_S__Suchithra
Hi, I am using OpenVino Version R2. I would like to visualize the OpenVINO IR model. When I tried to import my model to DL Workbench, there shows an error "Unsupported Type of Archive". Due to above reason, I couldn't visualize my model using DL Workbench. So can you suggest any method to visualize the same other than the DL workbench method. Looking forward for your reply. Thanks & Regards, Suchithra
HemanthKum_G_Intel
Hi Suchitra,
Use the Import Model button in DL Workbench. In this case, you must create an intermediate reference (IR) file for your specified model by manually running Model Optimizer, then archiving the generated *.xml and *.bin file into a  "*.zip" or "*.tar.gz" and finally, uploading the archive into DL Workbench.
Ref. https://software.intel.com/en-us/blogs/2019/08/26/introducing-the-new-openvino-dl-workbench
An alternative for model visulaizer is Netron
V_S__Suchithra
Thank You for your valuable information
