openvino lower precision
rongrong__wang
https://docs.openvinotoolkit.org/latest/_docs_IE_DG_Int8Inference.html
in this document, i see the sentence:
This means that 8-bit inference can only be performed with the CPU plugin on the layers listed above. All other layers are executed in the format supported by the CPU plugin: 32-bit floating point format (fp32).
so, i should use the data format fp32 if i use the GPU and other layers that are not in the list?
Thank you!
Shubha_R_Intel
Dear rongrong, wang
INT8 inference is supported by GPU but the performance is not good on our current GPUs so I would advise against using it.
Shubha
rongrong__wang
Shubha R. (Intel) wrote:
Dear rongrong, wang
Shubha
Thank you very much! I tried it and it really is like this
