Way to Retain Opened Image
Baventhiran
When performing Step 5, while the program runs midway, the image can remain open and program will continue running once image is manually closed.
Is there are way for image to remain open for other demos such as Text Detection Demo and Crossroads Demo?
Adli
Hi Baventhiran,
Thank you for reaching out to us. If possible, you could try adding '-loop' to the command and run the demo.
Adli
Baventhiran
Couldn't edit post to correct, here is the correct one for Crossroad Camera Demo
Adli
Hi Baventhiran,
Adli
Baventhiran
Hi Adli,
The -loop addition did make it work, thanks. I'll accept your post as solution then.
Adli
Hi Baventhiran,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Adli
