6577 讨论
What are the steps to migrate my TF trained model to the NCSv1?
员工
1,970 次查看
I know people have asked this already but i dont seem to find the real steps as everybody goes in a different way or i dont understart A.I good enough :sweat_smile:
So i used tensorflow 1.9 to train my model, i am using the train.py (legacy) and also tried with model_main.py (new script) both located in the …/research/object_detection folder from Tensorflow.
When training finishes a frozen graph is generated but i dont understand why that one doesnt work.
I am using SSD_inceptionV2_coco latest release on tf github. The trained model works great using just tensorflow code but if i tried to get the GRAPH file for the NCS it fails everytime, i am just not able to find the input and output nodes that work properly, there is alot on the internet to get those but i dont think i am doing it write.
I followed this guide: https://movidius.github.io/ncsdk/tf_modelzoo.html
But it seems it works only for the models in ncappzoo, i tried the commands in the site and worked fine. so i could get the GRAPH file. my ssd_inceptionv2_coco failed :(
So i check this link:
https://movidius.github.io/ncsdk/tf_slim.html
But the code dont seem to work with the model.ckpt-200000
This is my code:
----------------------------------------------------------------------CODE----------------------------------------------------------------------------------------------------------------------------
import numpy as np
import tensorflow as tf
from tensorflow.contrib.slim.nets import inception
slim = tf.contrib.slim
def run(name, image_size, num_classes):
with tf.Graph().as_default():
image = tf.placeholder("float", [1, image_size, image_size, 3], name="input")
with slim.arg_scope(inception.inception_v1_arg_scope()):
logits, _ = inception.inception_v1(image, num_classes, is_training=False, spatial_squeeze=False)
probabilities = tf.nn.softmax(logits)
init_fn = slim.assign_from_checkpoint_fn('model.ckpt-200000', slim.get_model_variables('InceptionV2'))
with tf.Session() as sess: init_fn(sess) saver = tf.train.Saver(tf.global_variables()) saver.save(sess, "output/"+name)
run('inception-v2', 299, 2)
I just dont know what to use for model variables, InceptionV2 gets me
--------------------------------------------------------------------OUTPUT1----------------------------------------------------------------------------------------------------------------
File "tf_slim_export.py", line 21, in
File "tf_slim_export.py", line 14, in run
File "/home/chop/.local/lib/python2.7/site-packages/tensorflow/contrib/framework/python/ops/variables.py", line 678, in assign_from_checkpoint_fn
raise ValueError('var_list cannot be empty')
ValueError: var_list cannot be empty
---------------------------------------------------------------------OUTPUT2---------------------------------------------------------------------------------------------------------------
i tried InceptionV1 and worked a bit better but i know that is not the option for sure:
2019-01-05 04:41:01.150820: I tensorflow/core/platform/cpu_feature_guard.cc:141] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
2019-01-05 04:41:01.220727: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:897] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2019-01-05 04:41:01.221057: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1392] Found device 0 with properties:
name: GeForce GTX 970 major: 5 minor: 2 memoryClockRate(GHz): 1.342
pciBusID: 0000:01:00.0
totalMemory: 3.94GiB freeMemory: 3.40GiB
2019-01-05 04:41:01.221070: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1471] Adding visible gpu devices: 0
2019-01-05 04:41:01.398357: I tensorflow/core/common_runtime/gpu/gpu_device.cc:952] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-01-05 04:41:01.398383: I tensorflow/core/common_runtime/gpu/gpu_device.cc:958] 0
2019-01-05 04:41:01.398388: I tensorflow/core/common_runtime/gpu/gpu_device.cc:971] 0: N
2019-01-05 04:41:01.398500: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1084] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 3121 MB memory) -> physical GPU (device: 0, name: GeForce GTX 970, pci bus id: 0000:01:00.0, compute capability: 5.2)
File "tf_slim_export.py", line 17, in run
init_fn(sess)
File "/home/chop/.local/lib/python2.7/site-packages/tensorflow/contrib/framework/python/ops/variables.py", line 697, in callback
saver.restore(session, model_path)
File "/home/chop/.local/lib/python2.7/site-packages/tensorflow/python/training/saver.py", line 1752, in restore
{self.saver_def.filename_tensor_name: save_path})
File "/home/chop/.local/lib/python2.7/site-packages/tensorflow/python/client/session.py", line 900, in run
run_metadata_ptr)
File "/home/chop/.local/lib/python2.7/site-packages/tensorflow/python/client/session.py", line 1060, in _run
raise RuntimeError('The Session graph is empty. Add operations to the '
RuntimeError: The Session graph is empty. Add operations to the graph before calling run().
So what am i missing? do i need to move to OpenVino? in order for this to work?
Do i need to train my model with tf_slim as mandatory step for NCSv1?
What am i missing? i have been using pretrained models with the NCSv1 and it work great for my security cameras, now i want to automate my house but i need a custom model but i just cant make it work with NCS. using a desktop is just to much resources for a smarthouse and alot of power and money as i might need the Nvidia card. So please allow me to keep playing with this device. love it.
0 项奖励
14 回复数
员工
1,546 次查看
This is my code:
import numpy as np
init_fn(sess)
run_metadata_ptr)
0 项奖励
员工
1,546 次查看
What is going on my post is just blank and it quite big why i dont see my post?
0 项奖励
员工
1,546 次查看
My post are showing blank, no idea why so ill do multicomments:
0 项奖励
员工
1,546 次查看
This is my code:
import numpy as np
0 项奖励
员工
1,546 次查看
init_fn(sess)
run_metadata_ptr)
0 项奖励
员工
1,546 次查看
init_fn(sess)
run_metadata_ptr)
0 项奖励
员工
1,546 次查看
0 项奖励
员工
1,546 次查看
init_fn(sess)
run_metadata_ptr)
0 项奖励
员工
1,546 次查看
0 项奖励
员工
1,546 次查看
init_fn(sess)
run_metadata_ptr)
0 项奖励
员工
1,546 次查看
  1. 1. Traceback (most recent call last):
  2.
  3. 2. File "tf_slim_export.py", line 21, in
  4.
  5. 3. run('inception-v2', 299, 2)
  6.
  7. 4. File "tf_slim_export.py", line 17, in run
  8.
  9. 5. init_fn(sess)
  10.
  11. 6. File "/home/chop/.local/lib/python2.7/site-packages/tensorflow/contrib/framework/python/ops/variables.py", line 697, in callback
  12.
  13. 7. saver.restore(session, model_path)
  14.
  15. 8. File "/home/chop/.local/lib/python2.7/site-packages/tensorflow/python/training/saver.py", line 1752, in restore
  16.
  17. 9. {self.saver_def.filename_tensor_name: save_path})
  18.
    1.
    2. File "/home/chop/.local/lib/python2.7/site-packages/tensorflow/python/client/session.py", line 900, in run
  19.
    1.
    2. run_metadata_ptr)
  20.
    1.
    2. File "/home/chop/.local/lib/python2.7/site-packages/tensorflow/python/client/session.py", line 1060, in _run
  21.
    1.
    2. raise RuntimeError('The Session graph is empty. Add operations to the '
  22.
    1.
    2. RuntimeError: The Session graph is empty. Add operations to the graph before calling run().
  23.
0 项奖励
员工
1,546 次查看
i just cant post the output what is going on? moderators please check this!
0 项奖励
员工
1,546 次查看
0 项奖励
员工
1,546 次查看
If you came for answers, stop using the NCSDK and switch to OpenVINO.
After that i was able to use the mo_tf.py and test it on one of the samples with my NCSv1 using the web documentation, is way better than NCS docs and very well done same as the OpenVINO SDK.
0 项奖励
回复
