6597 Discussions
What's the difference between Intel Caffe and SSD Caffe?
Hi !
As for the variable "CAFFE_FLAVOR" in the file ncsdk.conf", it could support configure Intel or ssd.
Could you help teach me what's the difference between them (Intel-caffe vs. ssd-caffe)? Thanks.
BTW, Is there any dependencies issue between Caffe and Anaconda?
Why does it work when installed SDK without Anaconda package?
regards,
Sam Hsieh.
@samhsieh About your question concerning Anaconda: there are known issues using NCSDK with it so use them separately. You should not have problems Caffe CPU/GPU and Anaconda package.
Hi Georgievm_cms,
Thanks for your reminder. After uninstalled Anaconda package, it works fine.
Is there any plan to fix the conflicts?
Samhsieh
@samhsieh At that point there are no plans to make NCSDK to work along Anaconda. Maybe in future.
