6577 Discussions
What setup does Intel recommend for video streaming "at the edge"?
Lowe__Benjamin
I was wondering if Intel could provide any recommendations for a low cost solution for the following task:
1. Obtain a 1080p camera feed from a HDMI/DVI source (e.g. This could be done via a inexpensive "game" capture device which converts it into USB data (UVC) or via custom hardware which can do this conversion.
2. Encode the stream into a compressed format (e.g. H264).
3. Stream this feed securely (encrypted) to a cloud service e.g. Amazon Kinesis.
A Rasberry Pi 3 is insufficiently powerful to do real time encoding and streaming at the same time. For example, one thing I was wondering is if Intel provide a compute stick that can be used for video encoding which might facilitate this.
Thanks for any help,
Shubha_R_Intel
Dearest Benjamin, the answer is that Intel CPUs can perform video encoding but with added GPU acceleration, performance is definitely better. I encourage you to browse https://ark.intel.com/content/www/us/en/ark.html and find a system which suits your needs.
There is also the intel compute stick you can explore.
Shubha
