6574 讨论
Where can I get the Myriad Development Kit (MDK)?
员工
6,620 次查看
Movidius appears to have a much more complete development kit for the Myriad 2 chip - the Myriad Development Kit. Where can I get hold of this? Does it come with some other evaluation board? Can it be used for working witht the Neural Compute Stick?
For info, the Movidius_MDK_Product_Brief.pdf document lists the following impressive list.
MDK TOOLS
• Integrated toolchain for SHAVE processors and RISC CPUs
• Vector optimizing compiler for SHAVE processors
supports C/C++ with extensive intrinsic support
• Assembler and Assembly optimizer
• GCC toolchain for RISC CPUs
• Standard ELF/DWARF Linker
• Myriad 2 Full Chip Simulator, bit-accurate and cycle- accurate
• Myriad 2 debugger supporting SHAVE and CPU cores,with TCL command line
• Function Trace Profiler, Sampling Profiler, and System
Trace Profiler
• Movidius Eclipse IDE supports full compile-profile-debug flow with application Graph Designer framework and integrated memory visualizer and image comparer
MDK CAMERA DEVELOPMENT KIT
• Unified Multi-camera Framework and component control, adaptable to different sensors
• Flexible ISP pipelines and scalable architecture
• Robust auto-functions – exposure, white balance,
and focus
• Camera calibration and sensor tuning tools
MDK LIBRARIES
• Over 300 Computer Vision Library kernels such as:
• Bitwise logical functions
• Boxfilters of various sizes
• Convolutions, convSeparable of different sizes
• AbsoluteDiff, Canny, AccumulateSquare/Weighted, and other functions
• CensusMatching
• CornerMinEigenVal
• Color conversions
• Dilate and Erodes of different sizes
• Gauss, Laplacian/sLaplacian
• HarrisResponse
• Histogram
• IntegralImage
• Maximum, maxPool, minKernel, minMax
• medianFilter of various sizes
• OpticalFlow PyrLK
• sumOfAbsDiff, sumOfSquaredDiff
• threshold filters
• whiteBalance functions
• Linear Algebra Library
• SGEMM matrix multiply
• Other BLIS functions
• ISP Library
• Mono & Bayer pipelines
• Lanczos & Bilinear scaling
• Warp, Purple Flare, Grey-desaturate, Mono-imbalance, Local Tone Map and many more hardware and software kernels
0 项奖励
10 回复数
员工
5,376 次查看
I would also be interested in running the MDK on my NCS.
0 项奖励
员工
5,376 次查看
MDK is build for the reference design kits rather than the NCS.
0 项奖励
员工
5,376 次查看
Is the MDK platform available for purchase?
How can one start to work with MDK?
0 项奖励
员工
5,376 次查看
+1.
Also interested in purchasing.
0 项奖励
员工
5,376 次查看
I'm also interested, but don't see anybody replied. Is Myriad project dead?
0 项奖励
员工
5,376 次查看
snake oil traders… they have nothing
0 项奖励
员工
5,376 次查看
The Myriad Development Kit is meant for customer purchases in large volume. Please visit the Movidius Contact site for non-NCS related inquiries.
0 项奖励
员工
5,375 次查看
+1.
Why not release it like ncsdk……..and let movidius grow !! ( since intel sells the hardware it seems pretty safe …and free work from the community )
Or..wait for another company to take lead….. ;)
https://aiyprojects.withgoogle.com/edge-tpu
https://gyrfalcontech.com/solutions/
0 项奖励
员工
5,376 次查看
Wait a second - you advertise the MDK and sell the device, but the device is a brick unless you're a large company, presumably with a huge amount of money? Don't you think that's a bit reprehensible?
0 项奖励
PGupt24
初学者
5,376 次查看
Even You have a project that can tern into big production they will not provide you any kits
0 项奖励
回复
