Windows installation instructions don't work
Kulecz__Walter
I've wasted most of the day on this :)
The Linux instructions had some problems, mostly root permissions on things copied/installed in my home directory but the demos worked after some chown -R commands.  I've successfully run some downloaded GitHub sample code and have been mostly impressed with the speedup of the NCS2 over the original NCS , although with a decent i5 CPU software only face detection is still a bit faster than with the NCS2.  On an old i5 lacking the AVX & AVX2 either NCS gives a higher frame rate than CPU only.  I haven't attempted the GPU install yet, not sure these "weak" i3 and i5 machines available to me have a new enough version of the integrated graphics.
In any event on Windows 10 I seem to have completed every step successfully but when I get to the "Use Demo scripts to verify your installation" it fails with ridiculous and contradictory error messages
I open a command promt.
setup the variables with:
and then:
cd C:\Intel\computer_vision_sdk\deployment_tools\demo\
followed by:
demo_squeezenet_download_convert_run.bat
Which errors out with:
Target folder C:\Users\MINI PC\Documents\Intel\OpenVINO\inference_engine_samples_2017 already exists. Skipping samples building.
If you want to rebuild samples, remove the entire C:\Users\MINI PC\Documents\Intel\OpenVINO\inference_engine_samples_2017 folder.
Waiting for 0 seconds, press a key to continue ...
###############|| Run Inference Engine classification sample ||###############
The system cannot find the path specified.
        0 file(s) copied.
classification_sample.exe -i c:\Intel\computer_vision_sdk\deployment_tools\demo\\car.png -m "C:\Users\MINI PC\Documents\Intel\OpenVINO\openvino_models\ir\FP32\classification\squeezenet\1.1\caffe\squeezenet1.1.xml" -d CPU
'classification_sample.exe' is not recognized as an internal or external command,
operable program or batch file.
Error
There clearly is no C:\Users\MINI PC\Documents\Intel\OpenVINO\inference_engine_samples_2017 directory when I look with the file browser.
If I do:
dir C:\Users\MINI PC\Documents\Intel\OpenVINO
I get: The system cannot find the path specified.
But if I do:
dir "C:\Users\MINI PC\Documents\Intel\OpenVINO"
I get:
0 files 0 bytes.
Clearly the installations scripts can't deal with spaces in folder/filenames.  Windows lusers seem to like spaces in folder/filenames.  Its not my system, I'm just trying to install OpenVINO on it.
How do I fix this? and why did it get this far without apparent problems?
Hill__Aaron
Modify the batch file to place quotation marks around the environment variables on every line that starts "if exists ..."
You may also have to define the http_proxy and https_proxy environment variables at the top of the script
You may also have to remove the --user argument from the call to pip if you are executing the script inside a pip virtual environment.
Implementing all those modification on my system allowed the batch script to execute without error.
Hill__Aaron
Kulecz__Walter
The more I click around the links about installing on Windows the more wrong information I'm finding.
For example in this video:
https://techdecoded.intel.io/quickhits/get-started-with-the-openvino-toolkit-install-on-windows/#gs.W6966GUo
States python 3.5 or higher is required.  This is wrong as the install fails at the pip install of tensorflow for lack of a version for python 3.7.1
Seems python 3.6.5 is the newest that will work to allow the "Configure the Model Optimizer" step to complete.
I'm stuck on step 5: "Run two demos"
Even doing it in a runas Administrator cmd window still doesn't work telling me:
When clearly it does not!
Kulecz__Walter
This appears to have gotten the examples to compile, i.e.  I have the exe file in Intel64\Release
But it appears that in the previous step to download and "compile" the models didn't work i.e. there is no OpenVINO\openvino_models  directory.
I also had to put quotes around the python commands.
I can see this is going to be a major PITA to get all the models downloaded. :(
Thanks for providing the "Rosetta Stone" clue!
