Writing Python script for the NCS-2
Bbill14
Hello everyone
I'm a new user of the NCS-2 and need a help on the creation of a testing script to use it with NCS-2 on Raspberry Pi. To start by creating a CNN to classify a Digit from 0 to 9, using the example described in the link below.
https://www.youtube.com/watch?v=y1ZrOs9s2QA
I have saved a Keras model, next, I turn Keras to TensorFlow model. By using the model optimizer I have converted the Tensorflow model to an IR file (.bin and .xml files) that we can use on the Neural Compute Stick 2.
I have run the following Python script on CPU and he is working as expected,
import numpy as np
import cv2
from keras.models import load_model
########### PARAMETERS ##############
threshold = 0.65 # MINIMUM PROBABILITY TO CLASSIFY
#### LOAD THE TRAINNED MODEL
model = load_model('./keras_model/model_keras.h5')
#### PREPORCESSING FUNCTION
def preProcessing(img):
  img = cv2.cvtColor(img,cv2.COLOR_BGR2GRAY)
  img = cv2.equalizeHist(img)
  img = img/255
  return img
imgOriginal = cv2.imread('cap5.png')
img = np.asarray(imgOriginal)
img = cv2.resize(img,(32,32))
img = preProcessing(img)
cv2.imshow("Processed Image", img)
img = img.reshape(1,32,32,1)
#### PREDICT
classIndex = int(model.predict_classes(img))
print(classIndex)
predictions = model.predict(img)
print(predictions)
probVal= np.amax(predictions)
print(classIndex,probVal)
if probVal> threshold:
  cv2.putText(imgOriginal,str(classIndex) + "  "+str(probVal),
        (50,50),cv2.FONT_HERSHEY_COMPLEX,
        1,(0,0,255),1)
  cv2.imwrite('cap5_pre.png',imgOriginal)
Now I need help with writing the testing script for the NCS-2 using the Openvino inference engine functions (IENetwork, IEPlugin).
Can anyone help me to do it?
David_C_Intel
Hi Bbill14,
Thanks for reaching out.
You can check our python samples and demos here, using our pre-trained models, and start from there.
Additionally, check the Inference Engine Python API Reference for more information.
Let us know if you have more questions.
David C.
A Contingent Worker at Intel
SSola8
As the Above comment may solve your issues, but just for complete understanding for the workflow. Here is my Template Code:
import time
import cv2
from openvino.inference_engine import IENetwork,IEPlugin
def check_result(y):
pass
def preprocess(frame):
pass
def postprocess(outputs):
pass
def run():
#global plugin used for loading model to MYRIAD Device
plugin = IEPlugin("MYRIAD")
# assuming IR Files is: "./text_detection.xml" & "./text_detection.bin"
# Load the model.
# root="./text_detection.%s"
model1 = "<model_path.%s>"
num_requests = 1
######### MODEL ###########
net = IENetwork(model%'xml',model%'bin')
device_model = plugin.load(network = net,num_requests=num_requests)
input_blob = next(iter(net.inputs))
out_blob = next(iter(net.outputs))
# get the input image
input_img = None
# preprocess the inputs
preprocessed_img = preprocess(input_img)
# Run on NCS
device_model.infer({input_blob: preprocessed_img})
# Get the outputs
# print("",result[out_blob].shape)
result = device_model.requests[0].outputs
# postprocess the outputs
output = postprocess(result)
if __name__ == "__main__":
run()
Bbill14
Hi
thank you DavidC_intel and SSola8
I will try to follow your instruction to write the correct python script.
Thanks again.
