Wrong output shape in compiled tanh layer
Hi everyone.
Recently I tried to port Deepgaze network on NCS. https://github.com/mpatacchiola/deepgaze/blob/master/deepgaze/head_pose_estimation.py
But compiled network always return wrong values.
During compilation following warnings appeared:
[Spoiler ]
! /usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py:766: DeprecationWarning: builtin type EagerTensor has no module attribute
! EagerTensor = c_api.TFE_Py_InitEagerTensor(_EagerTensorBase)
! /usr/local/lib/python3.5/dist-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead
! if d.decorator_argspec is not None), _inspect.getargspec(target))
! /usr/local/lib/python3.5/dist-packages/h5py/init.py:34: FutureWarning: Conversion of the second argument of issubdtype from float to np.floating is deprecated. In future, it will be treated as np.float64 == np.dtype(float).type.
! from ._conv import register_converters as _register_converters
! /usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/tensor_util.py:509: DeprecationWarning: The binary mode of fromstring is deprecated, as it behaves surprisingly on unicode inputs. Use frombuffer instead
! return np.fromstring(tensor.tensor_content, dtype=dtype).reshape(shape)
Network also doesn't pass mnNCCheck, so I tried to check part of it to find which layer causes problem.
Here is structure of network from mvNCProfile:
0 BiasAdd
1 Tanh
2 MaxPool
3 LRN
4 BiasAdd_1
5 Tanh_1
6 MaxPool_1
7 LRN_1
8 BiasAdd_2
9 Tanh_2
10 MaxPool_2
11 LRN_2
12 add
13 Tanh_3
14 add_1
15 output
So:
-in input
-on BiasAdd_1 - pass
-on Tanh_1 - throws an error: ValueError: cannot reshape array of size 32768 into shape (1,32,32,128)
-on MaxPool_1 - fails check because of low accuracy
Here is log for exception in tanh:
[Spoiler]
! mvNCCheck tf_model.meta -in input -on Tanh_1 -is 64 64
! Traceback (most recent call last):
! File "/usr/local/bin/mvNCCheck", line 152, in
! quit_code = check_net(args.network, args.image, args.inputnode, args.outputnode, args.nshaves, args.inputsize, args.weights, args)
! File "/usr/local/bin/mvNCCheck", line 137, in check_net
! timings, myriad_output = run_myriad(graph_file, args, file_gen=True)
! File "/usr/local/bin/ncsdk/Controllers/MiscIO.py", line 192, in run_myriad
! myriad_output = myriad_output.reshape(sz)
! ValueError: cannot reshape array of size 32768 into shape (1,32,32,128)
Then I compared graphs from tensorboard and mvNCProfile
And it appears that in mvNCProfile layers Tanh_1 and Tanh_2 has wrong output shape:
Tanh_1 takes tensor (128, 32, 32) and returns (32, 32, 32), but it should be also (128,32,32). In tensorboard this layer has right shape.
Tanh_2 input=(256, 16, 16) output = (16,16,16)
But "Tanh" and "Tanh_3" has right shapes (64,64,64) and (256,1, 1)
Images for Tanh_1 layer
[Spoiler]
! mvNCProfile:
! Tensorboard
Here you can find both graph images in full size:
tensorboard
mvProfile
I also tried to change tanh to relu. And in this case network was able to pass check and relu layers had right shape.
There is repo with small example, so you may try to reproduce this error. https://github.com/AlexSPN/Deepgaze-to-ncs-error
I use following environment:
NCSDK V1.12.00 2018-01-10
Python 2.7.12 - used for my scripts
Python 3.5.2 - seems to be used when I call mvNCCheck or mvNCCompile (at least in warnings python 3.5 was mentioned)
tensorflow 1.4.0
If I am missing out something, please let me know. Thanks!
@SPN Thanks for reporting this issue in such a complete manner. We were able to reproduce your issue and are investigating the root cause.
