YOLOv5s and YOLOv7-tiny
fizzgo
l want to run my own YOLOv5s and YOLOv7-tiny model on Raspberry PI 4B with NCS2.But I can't find the right tutorial on the Internet, so I ask for your help. Thanks.
Hairul_Intel
Hi Fizzgo,
For your information, OpenVINO does provide Object Detection Demo which is available from Open Model Zoo. However, do note that Yolov5s and Yolov7-tiny models are not listed in the Supported Models of the demo.
I would recommend you to try out this Object Detection & YOLOs demo available from GitHub repository: bethusaisampath/YOLOv5_Openvino. Hope this helps.
Hairul
fizzgo
I want to use python to run the YOLOv5s and YOLOv7-tiny with openvino. And my openvino version is 2021.4.752, l will try your recommendation. Thanks a lot.
fizzgo
I'm confused that the Github link you provided me didn't work successfully on Raspberry Pi. Thank you anyway. It didn't give any outputs or window, just nothing.
Hairul_Intel
Hi Fizzgo,
For your information, here are the Model Optimizer commands that I used to convert yolov5s model into Intermediate Representation (IR) format using openvino-dev[onnx] pip package:
mo --input_model yolov5s.onnx --output /model.24/m.0/Conv,/model.24/m.1/Conv,/model.24/m.2/Conv --data_type FP16 --scale_values=images[255] --input_shape=[1,3,640,640] --input=images
To find out your --input, --input_shape, and --output, please refer to this thread for more information.
On another note, you may use the following command in Object Detection Python Demo to do inference on MYRIAD with YOLOv5s model:
python3 object_detection_demo.py -at yolov4 -d MYRIAD -m yolov5s.xml -i <path_to_input>
Hairul
Hairul_Intel
Hi fizzgo,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Hairul
