benchmark_app fails at step 8
Brijender_B_Intel
Not sure, what is missing:
(base) c:\AI\CodeGen\cg350model\ov_model>benchmark_app -m openvino_model.xml
[Step 1/11] Parsing and validating input arguments
[ INFO ] Parsing input parameters
[Step 2/11] Loading OpenVINO Runtime
[ INFO ] OpenVINO:
[ INFO ] Build ................................. 2024.1.0-15008-f4afc983258-releases/2024/1
[ INFO ]
[ INFO ] Device info:
[ INFO ] CPU
[ INFO ]
[ INFO ]
[Step 3/11] Setting device configuration
[ WARNING ] Performance hint was not explicitly specified in command line. Device(CPU) performance hint will be set to PerformanceMode.THROUGHPUT.
[Step 4/11] Reading model files
[ INFO ] Loading model files
[ INFO ] Read model took 173.06 ms
[ INFO ] Original model I/O parameters:
[ INFO ] Model inputs:
[ INFO ] input_ids (node: input_ids) : i64 / [...] / [?,?]
[ INFO ] attention_mask (node: attention_mask) : i64 / [...] / [?,?]
[ INFO ] position_ids (node: position_ids) : i64 / [...] / [?,?]
[ INFO ] beam_idx (node: beam_idx) : i32 / [...] / [?]
[ INFO ] Model outputs:
[ INFO ] logits (node: __module.model/aten::to/Convert) : f32 / [...] / [?,?,51200]
[Step 5/11] Resizing model to match image sizes and given batch
[ INFO ] Model batch size: 1
[Step 6/11] Configuring input of the model
[Step 7/11] Loading the model to the device
[ INFO ] Compile model took 12218.41 ms
[Step 8/11] Querying optimal runtime parameters
[ INFO ] Model:
[ ERROR ] Exception from src\inference\src\cpp\compiled_model.cpp:145:
Exception from src\plugins\intel_cpu\src\node.cpp:503:
Node Broadcast_141508 contains less child edges than 1
Traceback (most recent call last):
File "C:\Users\bbharti\AppData\Local\anaconda3\Lib\site-packages\openvino\tools\benchmark\main.py", line 452, in main
value = compiled_model.get_property(k)
RuntimeError: Exception from src\inference\src\cpp\compiled_model.cpp:145:
Vipin_S_Intel
Hi Brijender, we would like to inform you that we are routing your query to the dedicated team for further assistance.
Megat_Intel
Hi Brijender_B_Intel,
We believe the error you received is due to the model itself. Could you please provide us with the model and the model information for further investigation?
On my end, I was able to run the OpenVINO™ 2024.1.0 benchmark_app on the model efficientdet-d1-tf:
Megat
Brijender_B_Intel
hi.
thanks for looking into this. The model is  hugging face model  salesforce/codegen-350M-muli converted to openvino through optimum command:
optimum-cli export openvino --model salesforce/codegen-350M-multi openvino_model
thanks
Brijender
Megat_Intel
Hi Brijender,
Thank you for providing us with the details.
For your information, I encountered a similar error when running the benchmark_app on the CPU device:
However, I successfully run the benchmark_app on the GPU device. You will need to specify the data shape since the model is dynamic. Please try to run the benchmark_app on the GPU device and specify the shape value using the parameter -shape "input_ids[1,1],attention_mask[1,1],position_ids[1,1],beam_idx[1]":
If you encountered the error "Incompatible MatMul matrix dimension", please reduce the number of iterations. On my end, selecting -niter 500 resolves the error.
On another note, I was able to load the model and successfully ran the inference using the code below for both CPU and GPU devices. The error seems to be related to the benchmark_app. We will investigate this issue and get back to you soon.
from optimum.intel import OVModelForCausalLM
from transformers import AutoTokenizer
model = OVModelForCausalLM.from_pretrained("openvino_model")
#model.to("GPU") - for GPU device
prompt = "def hello_world():"
tokenizer = AutoTokenizer.from_pretrained("openvino_model")
input_ids = tokenizer(prompt, return_tensors="pt").input_ids
generated_ids = model.generate(input_ids, max_length=128)
print(tokenizer.decode(generated_ids[0], skip_special_tokens=True))
Megat
Brijender_B_Intel
hi Megat.
Thanks for debugging it. Yes model inference runs fine but this tool was giving error. Looking forward for cpu fix.
-regards
Brijender
Hari_B_Intel
We have a response from our developer, after observing the error message from benchmark_app, it seems that when you convert the model to IR, you have to specify the input_shapes.
From the model, it seem like it train with BigQuery, but we couldn't get the input data to be inserted. If you ever got the information on the input data, you may want to try out insert the input data such as input_shape.
Hope this information helps
Thank you
Peh_Intel
This thread will no longer be monitored since we have provided answer and suggestion. If you need any additional information from Intel, please submit a new question.
Peh
