6584 Discussions
Newest release of OpenVINO™ 2024.4 is now available!
Luis_at_Intel
More Gen AI coverage and frameworks integrations to minimize code changes
  • Support for GLM-4-9B Chat, MiniCPM-1B, Llama 3 and 3.1, Phi-3-Mini, Phi-3-Medium and YOLOX-s models.
  • Noteworthy notebooks added: Florence-2, NuExtract-tiny Structure Extraction, Flux.1 Image Generation, PixArt-α: Photorealistic Text-to-Image Synthesis, and Phi-3-Vision Visual Language Assistant.
Broader LLM model support and more model compression techniques
  • OpenVINO™ Runtime optimized for Intel® Xe Matrix Extensions (Intel® XMX) systolic arrays on built-in GPUs for efficient matrix multiplication resulting in significant LLM performance boost with improved 1st and 2nd token latency, as well as a smaller memory footprint on Intel® Core™ Ultra Processors (Series 2).
  • Memory sharing enabled for NPUs on Intel® Core™ Ultra Processors (Series 2) for efficient pipeline integration without memory copy overhead.
  • Addition of the PagedAttention feature for discrete GPUs enables a significant boost in throughput for parallel inferencing when serving LLMs on Intel® Arc™ Graphics or Intel® Data Center GPU Flex Series.
More portability and performance to run AI at the edge, in the cloud or locally
  • Support for Intel® Core Ultra Processors Series 2 on Windows.
  • OpenVINO™ Model Server now comes with production-quality support for OpenAI-compatible API which enables significantly higher throughput for parallel inferencing on Intel® Xeon® processors when serving LLMs to many concurrent users.
  • Improved performance and memory consumption with prefix caching, KV cache compression, and other optimizations for serving LLMs using OpenVINO™ Model Server.
  • Support for Python 3.12.
  • Support for Red Hat* Enterprise Linux* (RHEL) version 9.3 - 9.4.
Download the 2024.4 Release
Download Latest Release Now
Get all the details
See 2024.4 release notes
NNCF RELEASE
Check out the new NNCF release
Helpful Links
NOTE: Links open in a new window.
