- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I'm getting the following:
[ 75%] Linking CXX executable upgrade_solver_proto_text
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyString_Size'
PyString_FromStringAndSize'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyString_FromString'
PyInt_Type'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyInt_FromLong'
PyFile_FromString'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyNumber_Divide'
PyUnicodeUCS4_FromEncodedObject'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyNumber_InPlaceDivide'
PyString_InternFromString'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyUnicodeUCS4_AsWideChar'
PyInt_AsLong'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyString_AsString'
PyString_FromFormat'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
PyClass_Type'
PyFile_AsFile'/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: undefined reference to
Py_InitModule4_64'
PyString_Type'collect2: error: ld returned 1 exit status
tools/CMakeFiles/upgrade_solver_proto_text.dir/build.make:137: recipe for target 'tools/upgrade_solver_proto_text' failed
make[3]: *** [tools/upgrade_solver_proto_text] Error 1
make[3]: Leaving directory '/opt/movidius/ssd-caffe/build'
CMakeFiles/Makefile2:517: recipe for target 'tools/CMakeFiles/upgrade_solver_proto_text.dir/all' failed
make[2]: *** [tools/CMakeFiles/upgrade_solver_proto_text.dir/all] Error 2
make[2]: Leaving directory '/opt/movidius/ssd-caffe/build'
Makefile:127: recipe for target 'all' failed
make[1]: *** [all] Error 2
make[1]: Leaving directory '/opt/movidius/ssd-caffe/build'
Installation failed. Error on line 498
I'm working on a 64-bit Ubuntu physical machine.
This is very frustrating because my NCS is arriving tomorrow and I'm dying to try it out after watching today's webinar on image recognition.
I'd be very grateful for any suggestions about how to deal with this. Thank you.
Tony
- Etiquetas:
- Caffe
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
p.s. Ubuntu 16.04
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
@TonyHoldroyd Glad you enjoyed the webinar. Regarding the installation issue, if you are using Virtualenv or Anaconda, the current NCSDK v 1.12 isn't compatible with either of those (I sometimes see this issue in those cases). If possible, I recommend installing the SDK on a fresh machine.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello Tome, thank you for your message.
Well, I'm not sure how but I managed to clear that error, above, with make install, which now works without complaint, but I'm now getting an error with make examples:
from mvnc import mvncapi
ModuleNotFoundError: No module named 'mvnc'
Makefile:80: recipe for target 'compile' failed
make[4]: *** [compile] Error 1
make[4]: Leaving directory '/home/tony/workspace/ncsdk/examples/caffe/GoogLeNet'
cp: cannot stat '../../caffe/GoogLeNet/graph': No such file or directory
Makefile:9: recipe for target 'googlenet' failed
make[3]: *** [googlenet] Error 1
make[3]: Leaving directory '/home/tony/workspace/ncsdk/examples/apps/multistick_cpp'
Makefile:12: recipe for target 'multistick_cpp/.' failed
make[2]: *** [multistick_cpp/.] Error 2
make[2]: Leaving directory '/home/tony/workspace/ncsdk/examples/apps'
Makefile:12: recipe for target 'apps/.' failed
make[1]: *** [apps/.] Error 2
make[1]: Leaving directory '/home/tony/workspace/ncsdk/examples'
Makefile:57: recipe for target 'examples' failed
make: *** [examples] Error 2
tony@DL-Box:~/workspace/ncsdk$
Again, any suggestions very gratefully received.
THanks
Tony
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I managed to fix this by locating mvnc and appending its path to my PYTHONPATH. To my great astonishment, the examples all then compiled without issue.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
@TonyHoldroyd Appreciate you coming back and posting your solution. Glad it worked out for you. The default PYTHONPATH is supposed to be: export PYTHONPATH="${PYTHONPATH}:/opt/movidius/caffe/python"
. What exactly did you have to change yours to?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Unfortunately, when I tried to 'make examples' again later, I got the same error as reported above:
ModuleNotFoundError: No module named 'mvnc' (The full error list is as above)
The module is there. What I had perhaps naively tried to do was put its path in as an extra line in .bashrc :
export PYTHONPATH="${PYTHONPATH}:/opt/movidius/NCSDK/ncsdk-86_64/api/python/mvnc"
which seemed to work the first time I tried it, but not consistently.
I would appreciate any suggestions you have.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
@TonyHoldroyd I suggest uninstalling the NCSDK using the uninstall.sh script and reinstalling the NCSDK (on a fresh machine if possible) using the following steps below.
- Open a new linux terminal. Change directory to your NCSDK directory.
- Uninstall your old NCSDK by typing in
./uninstall.sh
- Next change directories one level up by typing in
cd ..
and remove your NCSDK folder by typing inrm –rf ncsdk
- Clone a fresh version of the SDK by typing in
git clone https://github.com/movidius/ncsdk.git
- Install the NCSDK by typing in
cd ncsdk
and thenmake install
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
In the end, I decided to give up trying to install the ncsdk on my main machine and I installed it with no problems at all on an older but slower machine I have not used for a while with a fresh install of Ubuntu 16.04, just to be on the safe side.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
