can openvino use with normal GPU ?
Heng__Chin
can openvino use with normal GPU ? like Nvidia or AMD graphic card
Hyodo__Katsuya
Innovator
@Heng, Chin An example. It works normally using NVIDIA Geforce GTX 1070.
nikos1
Valued Contributor I
Yes, it will work fine with all GPUs but please note if you need to run clDNN inference (using for example -d GPU in the sample applications) it can only run on Intel GPUs ( HD5x or newer).
Cheers,
Nikos
