6584 Discussions
\common etait inattendu. while trying to run setupvars.bat
aicha
Hello intel,
I am a student, using intel openvino toolkit 2020.3 on .
Everytime I try to run setupvars.bat this error occurs:
\Common était inattendu.
Please help.
Thank you in advance.
Aicha.
Wan_Intel
Hi Aicha Ezzahra Sassi,
The error you encountered is not a common issue for OpenVINO™ Toolkit. We had difficulty to replicate this issue initially.
However, after trying various possibilities, I found that this error occurs if there are quotation marks added to the PATH for INTEL_DEV_REDIST System variable. System variables is located under Environment Variables.
Please remove the quotation mark for PATH of INTEL_DEV_REDIST and re-run the setupvars.bat. Please get back to us if the issue persists.
Wan
Wan_Intel
Wan
Wan_Intel
This thread will no longer be monitored since we have provided a solution.
If you need any additional information from Intel, please submit a new question.
Wan
