deblurring test
gb8
I managed to run deblurring demo.
the result is,
1. result image has no difference from original image.
2. result image shrinks sometimes.
3. quit loop doesn't work.
     interrupt key input check code seems to be wrong.
      current :  if key == 27 or key == 'q' or key == 'Q'
      working : if key in {ord("q"), ord("Q"), 27}    # in other example code.
4. After quit, image window doesn't disappears. It seems to need :
     - cv2.destroyAllWindows()
gb8
Vladimir_Dudnik
@gb8 I've tested demo with your image and see the same result as you (image still be too blurred), seems model can't process well such blurry images, doesn't matter if it was PNG or JPG (I've also tried to save image as JPG).
Vladimir_Dudnik
@gb8 Thanks for your report, we will look at exit condition in demo, this actually work for me (I've used cmd line like this: -d CPU -i <image> -m <model> --loop, and when I press ESC demo exit. Note, I've run demo and model from OpenVINO 2022.1 release.
For model itself, deblurgan-v2 is public model, pre-trained on GoPro (and some other) datasets, see model description for the details. So regarding training quality you may need to look at training pipeline in model's original repository. For quick test I've just used one image from GoPro dataset and I see the difference between original and resulting image (used -o <output_image> option to store result)
original imageoriginal imageresultresult
gb8
Thanks for quick reply.
I tried to run command mode, and the result is,
< content >
(ov) [OV_~/code/omz_demos/deblurring_demo] $ python deblurring_demo_org.py -i '/home/pi/code/dataset/blurry4.jpg' -m '/home/pi/code/models/public/deblurgan-v2/FP32/deblurgan-v2.xml' -d CPU --loop
Traceback (most recent call last):
File "deblurring_demo_org.py", line 27, in <module>
from openvino.model_zoo.model_api.models import Deblurring
ModuleNotFoundError: No module named 'openvino.model_zoo.model_api'
So, to solve path problem, I modified demo source(source upload not allowed).
  - append api module path to sys.path
  - manually feed args
But the result is same and with small image, very curious.
For cross check, I send the image file. And can you send me the file you tested?
I am testing on,
  - WSL(Ubuntu 20.04), VSCode, Python 3.8
Colorization demo works as expected.
gb8
gb8
I tested with the file in the mail(the street).
And the result is as you showed me.
The difference for now is your file is png, my test file is jpgs.
I will test the pngs tomorrow.
gb8
gb8
I appreciate for this great work.
I can use this work as it is, I am just reporting my observations.
Escape key and quitting result window works well on command line execution.
Just I tested on VSCode and Notebook for analyzing code, it was not.
The image you uploaded here also works well to me, but still my image doesn't work(jpg or pngs).
gb8
Vladimir_Dudnik
gb8
IntelSupport
Community Manager
Hi gb8,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Aznie
