detection model's output data
deeplearner
I read the code snippet;
for (auto &item : output_info) {
auto output_name = item.first;
auto output = infer_request.GetBlob(output_name);
auto const memLocker = output->cbuffer(); // use const memory locker
// output_buffer is valid as long as the lifetime of memLocker
const float *output_buffer = memLocker.as<const float *>();
/** output_buffer[] - accessing output blob data **/
Sorry, but I can't understand the last sentence "output_buffer[] - accessing output blob data"
The returned object is pointer to an array, and I should know the size of the array(number of detected things), but I can not find the way. Please help me!
Vladimir_Dudnik
@deeplearner  The InferRequest object allow to obtain output blob though GetBlob function (also used in your code snippet). And Blob object allow to obtain TensorDesc object, which has information about precision, shape and dimensions of data available through pointer, obtained by locking Blob memory buffer.
It might be better to look at some workable OpenVINO sample or Open Model Zoo demo to see how it usually implemented in applications.
  Vladimir
deeplearner
Thank you Mr. Dudnik for your kind reply! I fully understood what you said, so solved my problem.  If you allow me an another question, how can I see the "code" of 'workable OpenVINO sample' that you said? The site only shows working methods of samples.
Syamimi_Intel
Hi sinsik jin,
After installation of Intel® Distribution of OpenVINO™ toolkit, code С, C++ and Python* sample applications are available in the following directories, respectively:
  • <INSTALL_DIR>/inference_engine/samples/c
  • <INSTALL_DIR>/inference_engine/samples/cpp
  • <INSTALL_DIR>/inference_engine/samples/python
You can also refer the following link for Open Model Zoo demos:
https://github.com/openvinotoolkit/open_model_zoo/tree/master/demos
Syamimi
deeplearner
Thank you so much for your kind support!!!
Vladimir_Dudnik
Actually OpenVINO online documentation describes location of Demos and Samples, and it is sad to see that you can't find this information even with direct links which has this information just at the top of page for samples
After installation of Intel® Distribution of OpenVINO™ toolkit, С, C++ and Python* sample applications are available in the following directories, respectively:
and for demos
For the Intel® Distribution of OpenVINO™ toolkit, the demos are available after installation in the following directory: <INSTALL_DIR>/deployment_tools/open_model_zoo/demos. The demos can also be obtained from the Open Model Zoo GitHub repository. C++, C++ G-API and Python versions are located in the cppcpp_gapi and python subdirectories respectively.
Syamimi_Intel
Hi sinsik jin,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Syamimi
