does not appear to contain CMakeLists.txt.
AKALIN__Hasan
Hi everyone;
I have a problem for open vino.
pi@raspberrypi:~/build $ ls
pi@raspberrypi:~/build $ cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_CXX_FLAGS="-march=armv7-a" /opt/intel/openvino/deployment_tools/inference_engine/samples
CMake Error: The source directory "/opt/intel/openvino/deployment_tools/inference_engine/samples" does not appear to contain CMakeLists.txt.
Specify --help for usage, or press the help button on the CMake GUI.
pi@raspberrypi:~/build $ sudo usermod -a -G users "$(pi)"
bash: pi: command not found
usermod: user '' does not exist
how can i fix this problem? Thank you :)
Max_L_Intel
Hi Hasan.
You should further specify the path to either "c" or "cpp" samples directory as
/opt/intel/openvino/deployment_tools/inference_engine/samples/c/
or
/opt/intel/openvino/deployment_tools/inference_engine/samples/cpp/
Hope this helps.
Best regards, Max.
