facenet convert failed
Hi, i want to convert a facenet graph file from original facenet whose link is facenet VGGFace2 20180402-114759 using script below ncappzoo/blob/master/tensorflow/facenet/convert_facenet.py but failed.
Here is what i executed.
python3 convert_facenet.py model_base=model-20180402-114759.ckpt-275
and the error log is
/usr/lib/python3/dist-packages/h5py/__init__.py:34: FutureWarning: Conversion of the second argument of issubdtype from `float` to `np.floating` is deprecated. In future, it will be treated as `np.float64 == np.dtype(float).type`. from ._conv import register_converters as _register_converters model base file name is: model-20180402-114759.ckpt-275 Restoring model-20180402-114759.ckpt-275 Traceback (most recent call last): File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 1322, in _do_call return fn(*args) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 1307, in _run_fn options, feed_dict, fetch_list, target_list, run_metadata) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 1409, in _call_tf_sessionrun run_metadata) tensorflow.python.framework.errors_impl.InvalidArgumentError: Assign requires shapes of both tensors to match. lhs shape= [128] rhs shape= [512] [[Node: save/Assign_20 = Assign[T=DT_FLOAT, _class=["loc:@InceptionResnetV1/Bottleneck/BatchNorm/moving_variance"], use_locking=true, validate_shape=true, _device="/job:localhost/replica:0/task:0/device:CPU:0"](InceptionResnetV1/Bottleneck/BatchNorm/moving_variance, save/RestoreV2:20)]] During handling of the above exception, another exception occurred: Traceback (most recent call last): File "convert_facenet.py", line 99, in <module> sys.exit(main()) File "convert_facenet.py", line 76, in main saver.restore(sess, model_base_file_name) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/training/saver.py", line 1802, in restore {self.saver_def.filename_tensor_name: save_path}) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 900, in run run_metadata_ptr) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 1135, in _run feed_dict_tensor, options, run_metadata) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 1316, in _do_run run_metadata) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/client/session.py", line 1335, in _do_call raise type(e)(node_def, op, message) tensorflow.python.framework.errors_impl.InvalidArgumentError: Assign requires shapes of both tensors to match. lhs shape= [128] rhs shape= [512] [[Node: save/Assign_20 = Assign[T=DT_FLOAT, _class=["loc:@InceptionResnetV1/Bottleneck/BatchNorm/moving_variance"], use_locking=true, validate_shape=true, _device="/job:localhost/replica:0/task:0/device:CPU:0"](InceptionResnetV1/Bottleneck/BatchNorm/moving_variance, save/RestoreV2:20)]] Caused by op 'save/Assign_20', defined at: File "convert_facenet.py", line 99, in <module> sys.exit(main()) File "convert_facenet.py", line 64, in main saver = tf.train.Saver(tf.global_variables()) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/training/saver.py", line 1338, in __init__ self.build() File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/training/saver.py", line 1347, in build self._build(self._filename, build_save=True, build_restore=True) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/training/saver.py", line 1384, in _build build_save=build_save, build_restore=build_restore) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/training/saver.py", line 835, in _build_internal restore_sequentially, reshape) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/training/saver.py", line 494, in _AddRestoreOps assign_ops.append(saveable.restore(saveable_tensors, shapes)) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/training/saver.py", line 185, in restore self.op.get_shape().is_fully_defined()) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/ops/state_ops.py", line 283, in assign validate_shape=validate_shape) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/ops/gen_state_ops.py", line 60, in assign use_locking=use_locking, name=name) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/framework/op_def_library.py", line 787, in _apply_op_helper op_def=op_def) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/framework/ops.py", line 3392, in create_op op_def=op_def) File "/home/pi/.local/lib/python3.5/site-packages/tensorflow/python/framework/ops.py", line 1718, in __init__ self._traceback = self._graph._extract_stack() # pylint: disable=protected-access InvalidArgumentError (see above for traceback): Assign requires shapes of both tensors to match. lhs shape= [128] rhs shape= [512] [[Node: save/Assign_20 = Assign[T=DT_FLOAT, _class=["loc:@InceptionResnetV1/Bottleneck/BatchNorm/moving_variance"], use_locking=true, validate_shape=true, _device="/job:localhost/replica:0/task:0/device:CPU:0"](InceptionResnetV1/Bottleneck/BatchNorm/moving_variance, save/RestoreV2:20)]]
So the error was caused by shape mismatch by 128 VS 512
@shartoo So it looks like in the last update, the new model was changed from using 128 dimension embeddings to 512 dimension embeddings. If you have the facenet ncappzoo project, edit the inception_resnet_v1.py script in your facenet ncappzoo folder and change line 131 from:
bottleneck_layer_size=128, weight_decay=0.0, reuse=None):
to
bottleneck_layer_size=512, weight_decay=0.0, reuse=None):
and then change line 154 from:
to
Then try running the convert_facenet.py script again. Let me know if this works for you.
Ok thank you,i'll try it later and reply you.
Hi , so I tried the suggestion above, changing the two lines and running convert_facenet.py and here's what I get… there are remnants of 128 …
python3 convert_facenet.py model_base=facenet_celeb
model base file name is: facenet_celeb
2018-12-28 18:24:43.116767: I tensorflow/core/platform/cpu_feature_guard.cc:141] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
Restoring facenet_celeb
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1322, in _do_call
return fn(*args)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1307, in _run_fn
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1409, in _call_tf_sessionrun
run_metadata)
tensorflow.python.framework.errors_impl.InvalidArgumentError: Assign requires shapes of both tensors to match. lhs shape= [1,1,896,512] rhs shape= [1,1,896,128]
[[Node: save/Assign_317 = Assign[T=DT_FLOAT, _class=["loc:@InceptionResnetV1/Repeat_1/block17_5/Branch_1/Conv2d_0a_1x1/weights"], use_locking=true, validate_shape=true, _device="/job:localhost/replica:0/task:0/device:CPU:0"](InceptionResnetV1/Repeat_1/block17_5/Branch_1/Conv2d_0a_1x1/weights, save/RestoreV2:317)]]
sys.exit(main())
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/training/saver.py", line 1752, in restore
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 900, in run
run_metadata_ptr)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1135, in _run
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1316, in _do_run
run_metadata)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/client/session.py", line 1335, in _do_call
Caused by op 'save/Assign_317', defined at:
sys.exit(main())
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/training/saver.py", line 1284, in init
self.build()
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/training/saver.py", line 1296, in build
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/training/saver.py", line 1333, in _build
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/training/saver.py", line 781, in _build_internal
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/training/saver.py", line 422, in _AddRestoreOps
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/training/saver.py", line 113, in restore
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/ops/state_ops.py", line 219, in assign
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/ops/gen_state_ops.py", line 60, in assign
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/op_def_library.py", line 787, in _apply_op_helper
op_def=op_def)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 3414, in create_op
op_def=op_def)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 1740, in init
InvalidArgumentError (see above for traceback): Assign requires shapes of both tensors to match. lhs shape= [1,1,896,512] rhs shape= [1,1,896,128]
