6583 Discussions
follow the tutorialUnable to import yolov4-darknet to tensorflow model
LimFang
I have followed the instructions as stated in Tutorial Darknet* YOLOv4 Model — OpenVINO™ documentation — Version(latest) My yolov4.saved_model folder looks like this in the picture. When I try to upload the folder it takes way too much time and I keep getting this error after uploading 50%-70% of the folder: Can't retry wb.main.tasks.task.Task] args:(None, 'WaitModelUploadJob', 165) kwargs:{}
steps are as fllows:
Hari_B_Intel
Hi LimFang
For your information, DL Workbench has been updated to OpenVINO 2022.1 last week.
you may use the latest OpenVINO 2022.1 to analyze your model.
Thank you
LimFang
This is the convert.py .zip file
LimFang
This is my cfg file
Wan_Intel
Hi LimFang,
For your information, I encountered the same error as you. As a workaround, you can convert yolov4 model into Intermediate Representations with the following steps:
1.   Download a pretrained model file yolov4.weights from here.
2.   Git clone the converter repository with the following command:
git clone https://github.com/david8862/keras-YOLOv3-model-set.git
3.   Create a Virtual Environment:
python -m pip install virtualenv
python -m virtualenv venv
venv\Scripts\activate
4.   Install requirements
python -m pip install -r .\keras-YOLOv3-model-set\requirements.txt
5.   Convert Darknet Model to TensorFlow
python keras-YOLOv3-model-set\tools\model_converter\convert.py keras-YOLOv3-model-set\cfg\yolov4.cfg <path_to_weights_file>\yolov4.weights <output_dir>\yolov4.savedmodel --yolo4_reorder
6.
   Install the OpenVINO™ Development Tools Package
python -m pip install --upgrade pip
pip install openvino-dev[tensorflow2]
7.   Convert TensorFlow to Intermediate Representation:
mo --input_shape [1,608,608,3] --scale_values=image_input[255] --input=image_input --reverse_input_channels --saved_model_dir=yolov4.savedmodel
Hope it helps.
Wan
LimFang
Hi ,thanks for your attention.
all things goes well and the .xml .bin files are successfully created.
However,when i upload these into dl workbench some errors occurred as follows;‘
so what's wrong with it now? What does reader library path really means ?
LimFang
Wan_Intel
Hi LimFang,
May I know which version of the OpenVINO™ Deep Learning are you using?
You may check the version with the following command:
docker images
Wan
LimFang
Hi,Wan
Yeah it is as follows:
Lim fang
LimFang
well i am using the dl workbench online launched in jupte lab, and i'm just tring to make this project worked only online.
As a result, I have not download a local dl workbench yet.
Sincerely,
LimFang
Wan_Intel
Hi LimFang,
I encountered the same error as you did when uploading the model that was generated from the OpenVINO Model Optimizer 2022.1 to DL Workbench in the Intel® DevCloud for the Edge (Python 3 OpenVINO 2022.1).
Let me check with the relevant team, and I will update you once I’ve obtained feedback from them. Meanwhile, could you please install openvino-dev 2021.4.2 and convert the model again? You can install openvino-dev 2021.4.2 and convert the model with the following command:
pip install openvino-dev==2021.4.2
The model was able to upload to DL Workbench in the Intel® DevCloud for the Edge version Python 3 (OpenVINO 2021.4.2) as shown in the attachments below:
Selected Kernal for DL Workbench Launcher Python 3 (OpenVINO 2021.4.2):
Uploaded model that optimized using OpenVINO Model Optimizer version 2021.4.2.
Wan
LimFang
HI Wan,
I will try all as you have mentioned, and I'd like to tell you the result as soon as it works.
Lim Fang
Hari_B_Intel
Hi LimFang
Apology for the late reply due to Devcloud being under maintenance for the last 1 week.
After some investigation on the issue you are facing, we found that the DevCloud DL workbench currently does not support OpenVINO 2022.1 yet.
To fix the issue, my advice is to use OpenVINO 2021.4.2 and you should be able to Analyze your model.
Hope this information helps
Thank you
Hari_B_Intel
Hi LimFang
Thank you
