6614 Discussions
[help] debug for Exception: mvncStatus.TIMEOUT in OpenDevice
environment: docker in embedded linux (X64 NAS)
docker command:
sudo docker run -it --net=host -v /share/:/photo/ -v /dev:/dev --name ncsdk_container_test xshan1/ncsdk_container bash
output:
Traceback (most recent call last):
File "run.py", line 262, in
sys.exit(main())
File "run.py", line 215, in main
device.OpenDevice()
File "/usr/local/lib/python2.7/dist-packages/mvnc/mvncapi.py", line 147, in OpenDevice <-- not even open device
raise Exception(Status(status))
Exception: mvncStatus.ERROR
lsusb:(connected to usb 2.0 hub to down grade speed)
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 104: ID 05e3:0736 Genesys Logic, Inc. microSD Reader/Writer
Bus 003 Device 103: ID 03e7:2150
Bus 003 Device 102: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 003 Device 002: ID 125f:601a A-DATA Technology Co., Ltd.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
※If movidius connected to USB3.0 port in NAS directly I got only "segmentation fault" ,no traceback printed
Anyone has hint for debugging??
