how to use IP cam with openvino
Heng__Chin
can openvino use with IP cam instead of web cam ? if yes, how to setup ?
Hyodo__Katsuya
Innovator
@Heng, Chin Regardless of the function of OpenVINO, it can be processed by OpenCV. https://stackoverflow.com/questions/49978705/access-ip-camera-in-python-opencv
Heng__Chin
@Hyodo, Katsuya
import numpy as np
import cv2 cap = cv2.VideoCapture('http://username:password@10.10.XX.XX')
while(True): ret, frame = cap.read()
cv2.imshow('frame',frame)
if cv2.waitKey(1) & 0xFF == ord('q'):
break
cap.release()
cv2.destroyAllWindows()
tested code above but not working, and got this message below:
user@user-virtual-machine:~/Downloads$ python3 ipcam.py
(python3:4185): GStreamer-CRITICAL **: gst_element_get_state: assertion 'GST_IS_ELEMENT (element)' failed
Traceback (most recent call last):
  File "ipcam.py", line 16, in <module>
cv2.error: OpenCV(4.0.0-pre) /home/jenkins/workspace/OpenCV/OpenVINO/build/opencv/modules/highgui/src/window.cpp:356: error: (-215:Assertion failed) size.width>0 && size.height>0 in function 'imshow'
Hyodo__Katsuya
Innovator
You need to replace 1.username 2.password 3.ipaddress 4.port 5.path(xxxx) with the correct value. import cv2 cap = cv2.VideoCapture("http://username:password@xxx.xxx.xxx.xxx:port/xxxx") #cap = cv2.VideoCapture("http://username:password@xxx.xxx.xxx.xxx:port") while(True): ret, frame = cap.read() cv2.imshow('frame',frame) if cv2.waitKey(1) & 0xFF == ord('q'): break cap.release() cv2.destroyAllWindows() or import cv2 cap = cv2.VideoCapture("rtsp://username:password@xxx.xxx.xxx.xxx/1") while(True): ret, frame = cap.read() cv2.imshow('frame',frame) if cv2.waitKey(1) & 0xFF == ord('q'): break cap.release() cv2.destroyAllWindows() If there is no authentication setting, import cv2 cap = cv2.VideoCapture("http://xxx.xxx.xxx.xxx:port/xxxx") #cap = cv2.VideoCapture("http://xxx.xxx.xxx.xxx:port") while(True): ret, frame = cap.read() cv2.imshow('frame',frame) if cv2.waitKey(1) & 0xFF == ord('q'): break cap.release() cv2.destroyAllWindows() or import cv2 cap = cv2.VideoCapture("rtsp://xxx.xxx.xxx.xxx/1") while(True): ret, frame = cap.read() cv2.imshow('frame',frame) if cv2.waitKey(1) & 0xFF == ord('q'): break cap.release() cv2.destroyAllWindows()
Heng__Chin
@Hyodo, Katsuya
replaced username,password,port with correct value still having same output
[http @ 0x1e3d320] Stream ends prematurely at 0, should be 1581
(python3:5253): GStreamer-CRITICAL **: gst_element_get_state: assertion 'GST_IS_ELEMENT (element)' failed
  File "ipcam.py", line 17, in <module>
if using rtsp will get message below
[rtsp @ 0x2335920] method OPTIONS failed: 404 Not Found
(python3:5298): GStreamer-CRITICAL **: gst_element_get_state: assertion 'GST_IS_ELEMENT (element)' failed
Hyodo__Katsuya
Innovator
I do not know the type of camera you are using, so further advice is difficult.
Heng__Chin
I'm using DVR model: HV7108
Hyodo__Katsuya
Innovator
??? Probably, It is not a network camera. I do not know what you want to do.
Jia__Qingyu
I'm encountering significant lagging with IP camera with build inference engine sample for age, emotion and gender recognition models.
It will freeze the terminal most of the time.
My input is "-i rtsp:username:password@ipv4:port/video_path". Tried to scaled down the resolution, didn't see much improvement.
However it works a lot better with USB camera.
Any comments would be highly appreciated.
