image-classifier error on Pi
Have followed https://movidius.github.io/blog/ncs-image-classifier/ but at the step to make run I receive the error below, which appears to be related to incorrect caffe install?:
pi@raspberrypi:~/workspace/ncappzoo/apps $ cd image-classifier/
pi@raspberrypi:~/workspace/ncappzoo/apps/image-classifier $ make run
\making ilsvrc12
(cd ../../data/ilsvrc12; make;)
make[1]: Entering directory '/home/pi/workspace/ncappzoo/data/ilsvrc12'
make[1]: Leaving directory '/home/pi/workspace/ncappzoo/data/ilsvrc12'
making gendernet
(cd ../../caffe/GenderNet; make compile;)
make[1]: Entering directory '/home/pi/workspace/ncappzoo/caffe/GenderNet'
make[2]: Entering directory '/home/pi/workspace/ncappzoo/data/age_gender'
--2017-12-04 07:23:33-- https://github.com/GilLevi/AgeGenderDeepLearning/raw/master/models/mean.binaryproto
Resolving github.com (github.com)… 192.30.253.112, 192.30.253.113
Connecting to github.com (github.com)|192.30.253.112|:443… connected.
HTTP request sent, awaiting response… 302 Found
Location: https://raw.githubusercontent.com/GilLevi/AgeGenderDeepLearning/master/models/mean.binaryproto [following]
--2017-12-04 07:23:34-- https://raw.githubusercontent.com/GilLevi/AgeGenderDeepLearning/master/models/mean.binaryproto
Resolving raw.githubusercontent.com (raw.githubusercontent.com)… 151.101.16.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.16.133|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 786446 (768K) [application/octet-stream]
Saving to: ‘./mean.binaryproto’
mean.binaryproto 100%[===================>] 768.01K 415KB/s in 1.9s
Last-modified header missing -- time-stamps turned off.
2017-12-04 07:23:37 (415 KB/s) - ‘./mean.binaryproto’ saved [786446/786446]
Traceback (most recent call last):
File "convert_mean.py", line 3, in
import caffe
File "/opt/movidius/caffe/python/caffe/init.py", line 1, in
from .pycaffe import Net, SGDSolver, NesterovSolver, AdaGradSolver, RMSPropSolver, AdaDeltaSolver, AdamSolver, NCCL, Timer
File "/opt/movidius/caffe/python/caffe/pycaffe.py", line 13, in
from ._caffe import Net, SGDSolver, NesterovSolver, AdaGradSolver, \
ImportError: No module named 'caffe._caffe'
Makefile:5: recipe for target 'all' failed
make[2]: *** [all] Error 1
make[2]: Leaving directory '/home/pi/workspace/ncappzoo/data/age_gender'
Makefile:17: recipe for target 'prereqs' failed
make[1]: *** [prereqs] Error 2
make[1]: Leaving directory '/home/pi/workspace/ncappzoo/caffe/GenderNet'
Makefile:11: recipe for target 'gendernet' failed
make: *** [gendernet] Error 2
Hellow?
@robmarkcole In order to help troubleshoot your issue, I'd like to ask which version of the SDK are you using.
Hi @Tome_at_Intel I'm on v1.11.00.04 on a pi3 with Stretch release 9.3.
Cheers
